Is there a way to clean up double lines faster...
TJS
Post by TJS »
I am creating class reunion sign and the mascot is a tiger in which I will incorporate into my sign. Very close to the one I downloaded from Etsy. I did not look at the nodes really cause of course the etsy seller advertised this was cut ready. I went to do a test cut tonite and could not even open it in sheetcam. So I came back in the house on my laptop and did a node simplify in inkscape. Then I look closer and there are double lines everywhere in where I have to remove nodes here and there and then take a look at the overall shape and make sure i am not altering it. I stopped after a while as you can see in the attachment I only got a few done near the top of the head. Not sure if there is another program out there to remove these in one shot.
Thanks.
T.J.
tigertest.svg
Re: Is there a way to clean up double lines faster...
TJ - I opened you file with Design Edge and I see the same thing. I don't know of a quick method to delete them all at once. I can certainly do it, but may take 15 or 20 minutes for me to do. I'll check it out later this evening.
See if this will work for you. I just individually deleted all the duplicate paths using Inkscape.
tigertest rev 1.svg
I found several open paths that I missed with Inkscape. This one is clean.
You will need to be creative to keep some of the parts from falling out when cut. Perhaps do a layered piece.
tigertest rev 1.dxf
Joe Jones
Post by Joe Jones »
A CLEAN version of the tiger logo is probably somewhere in the Internet. Tell me specifically, what is the name of the team, and what school are they associated with?
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
16 Lasers
FREE DesignEdge Training!
PM sent.
TJS
Post by TJS »
Thanks David,
I really appreciate it. Do you have an SVG of the last one you did. I see some pieces will fall out. I have the text and other stuff ready in regards to my sign. I will just add the tiger in there when complete. I don't want to make a layered sign as I am going to back up this sign with orange plastic. The sign will be painted black. The school colors were black and orange back then. Since then they changed the mascot and the colors of the High School.
Thanks again.
T.J.
TJ - I replied to your PM a little while ago with the svg file. I just saw this post now. You could probably glue or otherwise attach the pieces that fall out to the orange plastic backing after painting them. That might be the easiest thing to do.
rdj357
Post by rdj357 »
adbuch wrote: Wed Aug 24, 2022 8:51 pm See if this will work for you. I just individually deleted all the duplicate paths using Inkscape.
tigertest rev 1.svg
David,
I checked it out with DE also. There was one noticeable path (stripe on the right cheek) where there was no closed path. I mirrored the other side and placed it correctly, then used the select tool to select all open paths at once and hit delete. selected it all and smoothed it to small margin (.005) in this case, combined a couple odd shapes (upper teeth and left pupil) so they were more like the rest of the drawing, detected intersections, fixed 4 or 5 spots and then it was ready to start any work to make cut ready depending on the application. Took about 3 minutes.
This probably isn't much help for the OP unless they're using Design Edge but wanted to share the steps I took to clean it up, hopefully it helps!
Robert Johnson
PlasmaCAM GURU & Instructor
ROKCRLER
Post by ROKCRLER »
Here is a quick way to remove the double lines.
~Select your object
~Turn off fill and turn on stroke
~Go to node editing
~Zoom in on the object and click one node you want to remove, press CTRL and A to select all, then delete.
~Continue until you remove all the double lines you want to remove.
~Turn on fill to see the outcome.
https://youtu.be/jRvwyS8kSwE
4x8 Dynatorch
PM85
~Mo~
TJS
Post by TJS »
Thanks Rokcrler. I think i did a derivative of that process.
TJS
Post by TJS »
adbuch wrote: Thu Aug 25, 2022 8:41 am TJ - I replied to your PM a little while ago with the svg file. I just saw this post now. You could probably glue or otherwise attach the pieces that fall out to the orange plastic backing after painting them. That might be the easiest thing to do.
Thanks again David. I would glue them on the backer plastic but I am not going to be the gate keeper of this sign as they want to possibly reuse the sign for the next reunion. I am afraid the handling of this sign, moving it, etc., may cause the glued pieces to fall off the plastic backer. I will post the complete sign when I am done. Hope to have it cut out soon. Thanks for the help and ideas everybody.
T.J.
I will be posting a video I just made to show how to use Inkscape to do this, I put it on the Google drive and when it finishes I will post it here.
Here is the video in a Zip file have fun
tiger.zip
TJS
Post by TJS »
acourtjester wrote: Thu Aug 25, 2022 10:13 am Here is the video in a Zip file have fun
tiger.zip
Thanks Tom. I just tried that and that is a lot easier than what I was doing.
T.J.
Joe Jones
Post by Joe Jones »
I took a shot at it. I don't know how close this is to the original.
TIGER DXF.dxf
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
TJS
Post by TJS »
Thanks Joe. I am going to work on this tonite in regards to the drop outs. Hope to stretch them a little to bridge them without changing the shape of the animal. Who knows, if this does not work I might use the flying tiger here. More to come.
T.J.
Joe Jones
Post by Joe Jones »
TJS wrote: Thu Aug 25, 2022 2:14 pm Thanks Joe. I am going to work on this tonite in regards to the drop outs. Hope to stretch them a little to bridge them without changing the shape of the animal. Who knows, if this does not work I might use the flying tiger here. More to come.
T.J.
Oh? I thought you needed this specific tiger. Will just ANY tiger do?
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
TJS
Post by TJS »
Joe Jones wrote: Thu Aug 25, 2022 2:25 pm
T.J.
This tiger is the exact match that was on the back of my Varsity Hockey Jacket and all our sports Jerseys/Uniforms way back when. So yes using this would be great but we will see.
ROKCRLER
Post by ROKCRLER »
TJS, what does the original logo look like?
4x8 Dynatorch
PM85
~Mo~
TJS
Post by TJS »
This is all I could find. I was back in the 80's. Since then the mascot has changed.
rdj357 wrote: Thu Aug 25, 2022 9:01 am
tigertest rev 1.svg
David,
Robert - I tried your method using the original file (opened with Inkscape and saved as dxf for import to DE). Which program did you use to convert the original svg to dxf for editing with Design Edge?
This is the file I started with.
tiger.zip
Thanks Tom! I watched your video and that is essentially how I did it. Path Break Apart, then just start deleting. I went pretty fast, so I probably did not always delete the proper version of the particular path. I like the way you zoomed in for a more accurate selection.
ROKCRLER wrote: Thu Aug 25, 2022 9:47 am Here is a quick way to remove the double lines.
~Select your object
~Go to node editing
Thanks Rokcrler! I will try your study you method. It's always good to see a different perspective.
TJS
Post by TJS »
Ok. I remembered I had a jump drive I got from RHM(Robin Hill Machine) a few years back. I found a "cat". Here is my sign. I however think the cat will fall out.
T.J.
reunionsign.svg
