Business sign
Business sign
Hi all,
Wondering if anyone is able to help me with this one? The text part I have no problem with obviously but the circular logo I can't seem to figure out a way to replicate or at least modify to make it work and still look like the original. I'm fairly new to all this and the sign is for my brother in law as a gift so shouldn't have too many problems with the customer being too picky. I do want it to look good however as this will be representing his business and could potentially lead to a lot of leads for me.
I am looking at doing the sign as a negative text sign and to possibly have LED lighting behind.
Any help or advice would be greatly appreciated!
Re: Business sign
Have you made an attempt? And what software are you using for your editing/file vector file creation? What size will your final sign be?
Your supplied image has very high resolution, so a bitmap trace will provide excellent results as far as fidelity goes. The question is - how close do you wish to keep your end result to the original? By that I mean all the detail in the curved area (rings/circles).
This could certainly be cut with all the detail, but then the problem becomes dealing with the actual cutter kerf width and the spacing between the adjacent rings.
Re: Business sign
Hi David,
I have made a few attempts but not getting the results. I use inkscape. Its really just the circle bit that I'm finding hard to replicate. Here is what I have attempted.
Cheers
Cheers
Re: Business sign
I was just about to post when yours came in.
Re: Business sign
I assume you are not pleased with your attempt and are looking for something closer to the original? What will be the overall size of your sign?
Re: Business sign
Yes not 100% happy with the circle part. The sign will be approx 1200mm w x 600 h
Re: Business sign
So about 48 inches wide. You need to achieve a "happy medium" between the actual original and what you have so far. More detail, but not so much that if falls apart and is not cuttable.
Re: Business sign
Let me take a look.
Re: Business sign
Hi David,
I just realised I can't see your jpg files because I wasn't a contributing member. I have just paid the fee to become a member but it says it may take a couple of hours.
Really appreciate you have taken the time to have a look. Hopefully I'll be able to see the images soon and will respond then.
Thanks again
Thanks again
Re: Business sign
Yes - it is good to be a contributing member - may benefits.
Re: Business sign
Thanks David. Can I ask what software you use for editing stuff like this?
Re: Business sign
I am using Plasmacam Design Edge.
Re: Business sign
You could take a look at this to see if it will get you started. You can check your spacing between rings and perhaps adjust to your liking. Let me know if you have any questions. Depending on how you are planning to mount it, some reinforcement or bridging may be required to keep the rings from "flopping around".
Re: Business sign
Thanks David. I cant seem to open that dxf in inkscape. If you are able to is there any chance you could save it in SVG?
Re: Business sign
...starting to look better I think??
Re: Business sign
I am planning on mounting it using 6 x stand offs then hopefully LEDs behind it
Re: Business sign
If it doesn't need to be exactly close to the original, then I think yours may look better.
Re: Business sign
Thanks David. If you didn't live approx. 15000kms away I would offer to buy you a beer!.
I'm really enjoying my CNC table and the help I am receiving on this forum is invaluable. Hopefully in a year or two I will be able to give back when I am more experienced!
Re: Business sign
Happy to help! By the way, I used LightBurn to convert from dxf to svg. You can also use Qcad to convert dxf R14 to dxf R13. Inkscape will open dxf R13 format. Let us know if you have more questions, and be sure to show us your sign when you cut it.
- Joe Jones
Re: Business sign
I really like this version. After all, those thin lines when illuminated from behind will not reveal the detail anyway. The thin bands of light will blur together and you will not get the results you seek. This design is conceptual, and conveys the same message using only three rings that are both able to be cut by a plasma table, as well as SEEN by the human eye. It will look great!
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Re: Business sign
Hey thanks Joe. This will be my first business sign so was hoping to make an impression that may lead to future work.
- Joe Jones
Re: Business sign
Are you going to put a thin sheet of white acrylic behind the front face? If you leave the can open, it will attract bugs, and dirt. With a white plex pace, you can concentrate your LED lighting to the area directly behind the openings. There is no sense in lighting the entire cabinet interior unless light must pass through the entire face to the outside.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
- Joe Jones
Re: Business sign
With signage, it is very important to make sure you are in compliance with ALL local sign codes and electrical codes. If the sign is a low voltage sign, then it is less troublesome, but if there is 120 VAC running to the sign, you might not be able to hang it or mount it without a UL Label for compliance with electrical codes. This means the sign MUST be wired by a license electrician. If it is outside, it will most likely need WEEP HOLES at the bottom of the can so rain water can escape.
Signage is a strange thing. If it blocks the view of another business sign, it may be taken down. If it exceeds the maximum square footage allowed for advertising space in that zone, it may be taken down. If it blocks access to fire sprinkler system valves, it will be taken down. If it is not in compliance with local DESIGN CODES, it will be taken down. If it is the wrong color, it may need to be repainted.
I would hate to see you sell the sign, and have the customer threatened with a large fine if it is not immediately taken down. Depending on WHERE it is being set up, there can be problems also. If it is at the end of a driveway for example, it cannot block the driver's view down the road. There are probably local fire codes that you must comply with also.
Setting up a lighted sign is one of the easiest ways to invite the State, City and Local gu'mints to crawl up your shorts. You can't believe how many ways you can violate local sign codes. I see that you are about 10,000 miles away, so your codes may be different, or more relaxed where you are.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
- Joe Jones
Re: Business sign
Where are you located?Improvise wrote: ↑Wed May 04, 2022 4:25 am Thanks David. If you didn't live approx. 15000kms away I would offer to buy you a beer!.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
Re: Business sign
Hi Joe,
Thanks for all the advice. The sign will be inside an office so shouldn't have too many problems. I was just going to use led strip lighting taped to the back of the sign following the outer edge of the cut outs.
I'm in Western Australia.
