Torch drags on part nomatyer where I calibrated
Weld-Teach
Post by Weld-Teach »
Ii have calibrated head with different settings from .13 to .38 for the distance.
Whenever I download G code and cut, torch lazily drags on my plate moving it around and causing it to stop.
Also not sure if when creating G code, how to select from the tools to ensure when cutting in mach3, that it recognizes material thickness being used.
Not sure if when I cut 10ga, does the torch think it 16ga and drags.???????
I'm at a loss, I can simulate cut, but torch tip just drags and engraves steel. I do have video.
Help!. Getting little help from Premier. They seem to be too busy for lil O me...
Weld-Teach
Re: Torch drags on part nomatyer where I calibrated
And I don't have THC. Was talked out of it when I ordered.
robertspark
Post by robertspark »
floating head switch offset been set correctly?
The material height is not involved in you problem, You need to set to both pierce height and cut height so it is in the G-code for mach to use. You also need to set Z0.0 in the DRO before you start. Also as Robert says if you are using a floating head assembly it will need to know the switch offset so the Z movement height is correct.
So you understand when the torch moves to the start of cutting Z moves down, when the tip touches the metal surface it moves down a little more to trip the floating head switch. Then Mach tell it to back up, it calculates the amount of switch offset and what is in the G-code to stop at the correct pierce height. The Z DRO should show the pierce height you set in the tool for the metal you are cutting.
For a test run in single step leave the plasma off.
cut 2.JPG (60.72 KiB) Viewed 494 times
