Harbour Freight Plasma
kennye
Post by kennye »
Im in the process of setting up a new table and I need to get a new plasma Im currently
using Hypertherm on my cnc Im using now is there anyone that is using the harbour freight plasma and how is it working out for you. Is their any suggestions on a good plasma that I could possibly use .I know its probably not going to perform like my hypertherm but its a money issue at this point thanks in advance.
WyoGreen
Re: plasma
Post by WyoGreen »
You're already using a top of the line plasma cutter, why not reuse it on the new table? As far as the Harbour Freight plasma cutter, I think I read on here in a past posting that it is a High Frequency start plasma cutter, which causes all sorts of problems with controllers and such.
Router
Laser
Re: plasma
There are (or used to be) some Harbor Freight plasma cutters with the "soft start", which is preferred for cnc plasma tables. If you are setting up a second table and keeping your Hypertherm with the existing table, then I understand. Otherwise - I agree with WyoGreen - why not keep your Hypertherm?
Re: plasma
Here is a 45 amp cutter from Harbor Freight which looks to be compatible for cnc cutting.
https://www.harborfreight.com/45a-plasm ... OoQAvD_BwE
The video shows this cutter being used with a small Langmuir table, so I assume it has the "soft start" feature.
https://www.youtube.com/watch?v=wtodZkGabUo
Re: plasma
Here is another one that is cnc compatible and seems to get good reviews.
https://primeweld.com/products/cut-60-2 ... sma-cutter
kennye
Re: plasma
Post by kennye »
I have all intentions in keeping my hypertherm its just Im setting up another table
and would like to be able to use both if needed and at this point Im kinda watching my pennies
until this country gets headed back in the right direction that is if it ever does. thanks for the advice
