23 INCH CLOCK WITH RECYCLED FENCE BOARD
gblaylo
Post by gblaylo »
The clock is made with old recycled fence boards glued to an OSD board as backer plate. Metal is powder coated Stone Black along with the screw heads. The clock clock movement was purchased from Hobby Lobby.
greggomc
Re: 23 INCH CLOCK WITH RECYCLED FENCE BOARD
Post by greggomc »
Very nice. The wood and powder coat compliment each other. What diameter is it?
Nice work on your 23" diameter clock!
jmersereau
Post by jmersereau »
Very nice clean design.
Jim
PrimeWeld CUT60
Langmuir CrossFire Pro
Nice clock! Glad to see someone go with the classic roman-numerals for 4 & 6, looks great!
Maadman
Post by Maadman »
Nice design. Can you tell me how you adhered the clock face to the weathered boards? I have tried several methods and don't feel like I have come up with the best solution.
Post by djreiswig »
From the picture it looks like he used small screws around the inner and outer circle. If you zoom in you can see them.
jmersereau
I just noticed that you appear to have mirrored the 6 to create the 4 and the V is backwards.
Jim
PrimeWeld CUT60
gblaylo
Post by gblaylo »
I'm pretty sure i got the clock face off of this site. Never noticed the V being backwards. I did have to modify the design some because the numbers were a bit out of time when I checked them, The face is held on with small sheet metal screws.
jmersereau wrote: Tue Jul 06, 2021 9:43 am I just noticed that you appear to have mirrored the 6 to create the 4 and the V is backwards.
Jim
That's a good find! I never would have noticed that.
Blackslacks
Post by Blackslacks »
Why are the roman numerals for 4,5,6,7,and 8 upside down?
Post by djreiswig »
They're correct from the center.
jmersereau
Blackslacks wrote: Wed Jul 07, 2021 11:02 am Why are the roman numerals for 4,5,6,7,and 8 upside down?
I think that these look right and I have never seen one with the Roman Numerals inverted on the bottom.
Jim
PrimeWeld CUT60
Blackslacks
i know most roman numeral clocks are like that but I don't know why cause it makes no sense to me
Post by tnbndr »
Blackslacks wrote: Wed Jul 07, 2021 3:40 pm i know most roman numeral clocks are like that but I don't know why cause it makes no sense to me
I agree!
But nice project design.
cdrake
Post by cdrake »
I am a teacher and I am looking for a roman numeral clock to help with a design for a student could I get that file?
bhamer62
Post by bhamer62 »
That's pretty cool, you could scale it down a smidge and it would fit perfect on a wine barrel head....They're like 21-1/4" ish diameter....and use wine stained side as the front if you wanted......
gblaylo
Post by gblaylo »
cdrake wrote: Fri Jan 14, 2022 10:03 am I am a teacher and I am looking for a roman numeral clock to help with a design for a student could I get that file?
I have downloaded the clock face file in the file sharing section. Hope you can and your student can use it.
Gary
