Weather Vane Toppers
- jmersereau
Here are some weather vane designs that I collected from this and other sites with minor changes...
Jim
Jim
PrimeWeld CUT60
Langmuir CrossFire Pro
Re: Weather Vane Toppers
Very nice. Thank you.
- Larry83301
Thanks, they all look nice!
GREAT! Thanks
Very cool!!
- kchoghead
these are cool!
Great job!
I needed a new Witch!
Thanks for sharing!
Thanks for sharing!
these are just beautiful thank you for sharing
These look great! Thanks for sharing.
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Thank you!
to jest super
Thanks very cool
Do you have the DXFs for these. There is no attachment.
You should be able to do a simple auto trace with Inkscape and save as dxf. You can use the search function to learn more. I'm pretty sure I have shown a step-by-step on how to do this several times in the past.smtechster wrote: ↑Thu Sep 30, 2021 11:39 am Do you have the DXFs for these. There is no attachment.
Here is one of them to get you started. Try to do some of the others yourself and let us know if you have any questions.
Great Share Thanks
Here's one I drew
Mick
Owner/ operator
MJT rural Contracting
Weldclass t1200
Hypertherm Pwermax 45XP
Owner/ operator
Weldclass t1200
Nice Work!! And a nice clean file! Thanks.
Made a rooster weather vane . Set it at the balance point and it spins in the wind. Tried the pivot point a little forward and it kind of points into the wind, but also swings back and forth. What would be your suggestion?
This might help you.smtechster wrote: ↑Wed Aug 31, 2022 10:08 pm Made a rooster weather vane . Set it at the balance point and it spins in the wind. Tried the pivot point a little forward and it kind of points into the wind, but also swings back and forth. What would be your suggestion?
https://www.baynews9.com/fl/tampa/weath ... ather-vane Perhaps your "head" is too large in relation to your "tail". Maybe post a photo of yours so we can take a look.
Sean P did weather vanes here in the past, I think the larger portion needs to be behind the pivot point. Look at it like you are going vertical if you want the tip pointing up it need more in the bottom. The wind will make it act like gravity does. I did not do weather vanes but a wind mill, I had to add the black face to make it work better
https://www.youtube.com/watch?v=LqFOnoz ... wq0KTKpuRw
Tom- that's what I was thinking also. The smaller arrow portion points to the front, and the larger tail is at the rear. So it is actually out of balance and not pivoting at the center balance point. It will be interesting to see how he has his rooster set up.
Okay, not as easy as it looks. major mass of vane to rear to act as a sail, then add weight to the front (arrow) to balance the vane. I will give that a try. Thank you!
