Powermax 45XP Raw Arc is gone!
Hi everyone. Today in my workshop i wanted to hook up my Powermax 45XP to a CNC table. This table has an XPTHC-4 THC from Hydcnc. Table controller is startcnc. Very strange setup. I have realized that THC voltage divider board need 1:1 raw arc voltage. So i dissasambled the cover of the XP45 and located the raw arc + and - . When i fire torch it varies all over on the multimeter from 45 to 521V. What can be wrong? On the CPC port 50:1 volt is stable. When i fire torch approx. 2,8Volts. Any idea?
Re: Powermax 45XP Raw Arc is gone!
blowback start
I don't think that's all that strange. Your monitoring a range of 0-100's of volts compared to divided where your monitoring 0-2 or 3 volts. I would expect to see a bigger swing. I find raw voltage very easy to work with and have always had better luck with it than divided anyway. Hook it up and giver er a go.
The problem is that it is abnormal. i had powermax 65 and 85 as well before. But never seen 520Volts coming out when torch fired.
Yes, that does sound high but I am nor pro so maybe its not uncommon. Was the arc transferring to the material or was it free air? If you cut a simple straight line at the correct cut height or .060" what is your arc voltage read on the voltmeter?attila0216 wrote: ↑Mon Aug 31, 2020 10:26 am The problem is that it is abnormal. i had powermax 65 and 85 as well before. But never seen 520Volts coming out when torch fired.
ok guys it was THC fault. New THC shows correct value
Thanks for the update.
Ah man, go figure. I had just assumed you were reading voltage with a multimeter when I replied. Glad you sorted it out and thanks for posting your solution.
