Plasma cam not initializing
Machine control error: unable to initialize machine. Could not detect limit switch opening on: carriage gantry.
Basically when I initialize the machine it starts moving very slowly towards home but only making it a couple inches until it errors. I squared the table. I started it and tried pressing either of the two buttons and neither had any effect. The machine was previously moved from a shop to this house. And hasn’t worked since. I also have rapid travel speed all the way up but only moves at like 5 inches per minute.
Re: Plasma cam not initializing
If the gantry is knocked off by a tooth on the rack such that it is not square with the table, it is possible that the gantry limit switch will not be activated. Check that when your gantry is in the home position that both ends of the gantry are touching the table stops. Otherwise check the Video Manual, Chapter 8, Motion Control Errors for the proper trouble shooting procedure.
I already squared it. No this is not the issue. Where can i find the manual?
You can purchase a replacement Video Manual here.
https://owners-community.com/order_part ... 8361da04c6
Does anyone know what could be wrong or encountered this issue before?
Test your limit switches. This is described in the Video Manual.
- rdj357
Check your rapid travel speed setting in machine control. If this gets set extremely low it can cause this error. Try setting it to 500 or more inches per minute.
Robert Johnson
PlasmaCAM GURU & Instructor
It is all the way up to 1000 if you read my original post
Which two buttons did you try pressing? Have you tested your limit switches?Bbrayden85 wrote: ↑Wed Sep 30, 2020 8:49 pm Machine control error: unable to initialize machine. Could not detect limit switch opening on: carriage gantry.
- rdj357
Sorry, it didn't say 1000 so I never assume that 'all the way up' means that.Bbrayden85 wrote: ↑Sun Oct 04, 2020 12:52 am It is all the way up to 1000 if you read my original post
Have you checked your limit switches in diagnostics? indicators for the limit switches should go yellow when pulled into the home corner and white when away.
Robert Johnson
is it wrong I chuckled?rdj357 wrote: ↑Mon Oct 05, 2020 2:36 pmSorry, it didn't say 1000 so I never assume that 'all the way up' means that.Bbrayden85 wrote: ↑Sun Oct 04, 2020 12:52 am It is all the way up to 1000 if you read my original post
Nah, I chuckled alsoCasaba wrote: ↑Mon Oct 05, 2020 6:26 pmis it wrong I chuckled?rdj357 wrote: ↑Mon Oct 05, 2020 2:36 pmSorry, it didn't say 1000 so I never assume that 'all the way up' means that.Bbrayden85 wrote: ↑Sun Oct 04, 2020 12:52 am It is all the way up to 1000 if you read my original post
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
- rdj357
Errybody needs a good laugh!
Speaking of captain obvious stuff, I wonder if they had the motor harnesses backwards? Hmmm
Robert Johnson
