Rottweiler Help
Rottweiler Help
I need help seperating the colors for a mural piece for a friend's celebration of life. Is there anyone who can help me out.
Thanks in advance. Looking for svg or DXF. I'm going to do a multi layer piece.
Re: Rottweiler Help
Not sure what you actually mean by "separating the colors", but here is a quick auto trace. Hopefully you can clean it up and edit to achieve your desired result.
Re: Rottweiler Help
You can use Inkscape to do what you want here are some of the steps. Import the drawing then click on path then trace bitmap. A menu with appear click on color (shown in the attached image) then reduce the color number to 3 and then Ok this will put the trace image on top of the original. move the traced and delete the original. Highlight the traced and click on path and then break apart, now under view click on display and then outline. You will now have the drawing separated into the different items and you can select for cutting independently.
When done go back to view and display and click on normal or it will stay in outline for the next trace (whoops).
Re: Rottweiler Help
Ok - Now I understand what you are after.
Here is your file with colors separated into 3 layers. The tan will need some cleanup.
Re: Rottweiler Help
And here are the 3 layers as individual dxf files.
Re: Rottweiler Help
All that education and help and not a "Thank you" in sight four days later.
I"ll say it. Thank You guys.
I may not have have asked for it, but the lessons will still help me out on other stuff.
Dan Owens
5x10 FastCut CNC Icon Elite plasma table
TurboCad,SheetCam,Mach3
Shapeoko3 CNC Router
and all the usual welders and tools to run a Fabrication shop.
Re: Rottweiler Help
Thanks Owens, it seems par for the course, some say thanks and some not, at least help was given.
- ben de lappe
Re: Rottweiler Help
In Soter907's defense he hasn't been on since Monday August 3rd at 11:39 p.m. according to his last active status, 7 minutes after he posted this thread. Maybe when he asked for help he didn't mean right then.Owens Customs wrote: ↑Sat Aug 08, 2020 2:11 pm All that education and help and not a "Thank you" in sight four days later.
Re: Rottweiler Help
Thanks you guys for the great tips and tricks.
Regards
Bob
Regards
Bob
Re: Rottweiler Help
ben de lappe wrote: ↑Mon Aug 10, 2020 2:46 amIn Soter907's defense he hasn't been on since Monday August 3rd at 11:39 p.m. according to his last active status, 7 minutes after he posted this thread. Maybe when he asked for help he didn't mean right then.Owens Customs wrote: ↑Sat Aug 08, 2020 2:11 pm All that education and help and not a "Thank you" in sight four days later.
I wasn't meaning to pick on anyone individually. I realize that some people will get help privately and have communications in private. It just seems that we mostly see only half of the process in public.
I was super impressed at how much information was shown in this thread by all parties involved.
Dan Owens
Re: Rottweiler Help
I have not heard back from the OP - either public or private. But that's OK - it's still fun for me to work on these files, and quite often I learn something new as well.
Re: Rottweiler Help
Sorry I just got back online. Thank you guys so much that is a huge help! I want to learn to do this and the turtorial is huge. Thank you. I cannot explain my absence but I am back as of now. Again thank you all.
Re: Rottweiler Help
Glad to hear you've got your computer back up and running. We'd all like to see the end result once you cut and finish it.
