I got a wrightcnc table. Nobody can get ahold of them for support, so I’m on my own. It’s using nema23 motors. They take all the labels off the motors so I have no clue what they are. I’d like to have one on the shelf for a spare.
Where could I look to figure that out? Mach3? Motor driver boards?
They are dual shaft, 1/4” or 6.35mm. Nema23. Grey base and top, with black center section. 4.360” body.
How do I figure out what Oz they are?
How to figure out nema23 motor
Re: How to figure out nema23 motor
It's going to be a guess imo
https://www.ebay.co.uk/itm/303564437536
These are 8mm shaft size.... But if you flip through the images there are 3x 112mm long stepper motors shown, so one of them may be 1/4"
Have a look at the drives and see if you can tell what the amperage is set at for the stepper motor drives
Driver boards with the pins to the on position/down.
Sw2
Sw5
Sw6
Sw8
All the other switches are up.
Sw2
Sw5
Sw6
Sw8
whats the driver? Any numbers on it?subisquared wrote: ↑Mon Jun 15, 2020 10:25 am Driver boards with the pins to the on position/down.
Sw2
Sw5
Sw6
Sw8
photo?
20v-50Vdc on the drivers. There’s no branding or labels on them either.
See if this shows up
If you can move the cables out of the way and photo the amperage table I can tell you what the current + range ofthe stepper drives and their likley part number
The external e-stop died on me today. So it’s now directly hot wires.
