Hi
when i run a g code the machine works fine. But sometimes the same g code torch stops at the go.????, I try to go back to line G5 sometimes work . sometimes stop at G 00.
i want to understand where is problem .
Maybe air not dried??...
Plz help me
The torche stop
The torche stop
Re: The torche stop
Your problem I suspect is that your license is fake
https://www.machsupport.com/forum/index ... #msg241118
Artsoft kindly added some bugs to mach3 so that when you install it with a copied licence it does strange things so that it damages your work / cuts .... On the basis of it serves you right for using a fake licence
I would suggest you switch to uccnc and buy a CNCdrive motion controller.... Or switch to Linux and run linuxcnc with plasmac... As it will be cheaper than buying a $175 USD mach3 licence for software that is no longer developed.... And essentially obsolete with many known bugs and nuances that uccnc and linuxcnc have resolved over time.
Re: The torche stop
Thank you very much for the information . yes maybe the mach 3 license. please what is the version you recommendrobertspark wrote: ↑Mon May 11, 2020 9:33 am Your problem I suspect is that your license is fake
Re: The torche stop
Ok there is another thing in play if you do not have a license you are limited to 250 (around that amount) lines of code. In you first image the line count is 274
![Sad :Sad](./images/smilies/icon_new_sad.gif)
![Funny :HaHa](./images/smilies/icon_new_haha.gif)
Re: The torche stop
Thanks. I think the problem is about the licenseacourtjester wrote: ↑Mon May 11, 2020 1:04 pm Ok there is another thing in play if you do not have a license you are limited to 250 (around that amount) lines of code. In you first image the line count is 274![]()
