Torchmate CNC Table
Torchmate CNC Table
I purchased a Torchmate CNC Table that is approx. 5 yrs old. The problem I'm having is that 1 stepper motor moves in the opposite direction as the other motor. I've switched them and checked the axis connections but still get the same results. Any thoughts? Motor going bad?
Re: Torchmate CNC Table
Could certainly be a motor going bad or is could just be that its wired backwards. Try swapping the two motors to the opposite sides and see if the problem remains the same or if the problem moves to the other side.
Unfortunately, I did swap the motors and the problem persists. Is Torchmate the only one that carries these motors?
If you swapped the motors and the problem remained on the same side than its the wiring or the motor driver.
If you swapped motors and the problem moved to the other side than it would be the motor.
In the driver software (depending what setup you have) you can change what direction you want motors to run. Or perhaps someone has wired a drive card to run in reverse polarity if it was used as a slave stepper before step and direction wires may be reversed.
-Dan
-Dan
