How to get a complete cut
My table always leaves a tab on random parts that I have to break off and grind. How do I get rid of these? I’m using Inkscape, sheet cam and Mach 3. I do not have holding tab selected.
Re: How to get a complete cut
Sounds like the torch is beginning to move before it has pierced the material. Try increasing your pierce delay time by 1 second and if that fixes it dial it back a little until you find the perfect pierce time. You don't want it to pierce longer than needed as it will accelerate consumable wear.
Thank you Weldguy I didn't think of that, I will give that a shot! i believe its set at 1 right now.
- SeanP
Best way I find is to use rules in sheetcam, you can stop it completely adding a small slowdown at the end, you may need to slow more on thicker material.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- tnbndr
You should also play around with lead in and lead out settings. I use perpendicular with .125 in and .125 out, that solved the tab problem for me.
Although I am going to try SeanP's path rule for the end of cut as my THC always dives at the end, turning it off should fix that.
I've had that happen a couple times.I have a PlasmCam I shut it down and restarted it. I also replaced the tip.Started cutting a full line again.
Jim
Jim
