I have a need to make many small parts (1.5" x 2.1/4") and trying to grind them is a killer on the gloves and finger tips.
I have seen several remarks in different areas of people who talked about using H.F. cement mixer ? is this for real ?
and most of all does it work ?, any suggestions on the media to put into it that will help work ??
any suggestions, comments or advice would be VERY MUCH APPRECIATED,
I really need something hopefully you can help guide me in the right direction.
goldwinger
Using Cement Mixers for Slag & Dross Removal ?
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
Re: Using Cement Mixers for Slag & Dross Removal ?
viewtopic.php?f=85&t=27002&p=162546&hil ... er#p162546
there are others if you use the search function upper right for cement mixer
I put Cement Mixer in the search field but in came up blank ?
BUT Thanks for your information and pointing me in the right direction, it sounds like this is what I need to do for the small parts.
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
- Scratch
I used to use a cement mixer for dross removal and it worked great! My mixer went belly up though and I haven't replaced it yet...
I was also using an old dryer for a while that also worked until the magic smoke escaped.
I use a Harbor Freight large cement mixer for a tumbler. Straight steel, no aggregate. Loud as HELL, but works well on parts that are durable enough to not bend/deform.
- SeanP
I made this for my mixer, not just as harsh as the mixer drum, it has a lid on as well, keeps in the dust and makes a lot less racket.
https://photos.app.goo.gl/bJPNimUDh4gx2mTP8
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
Clever ideaSeanP wrote: ↑Sun Jul 07, 2019 6:06 pm I made this for my mixer, not just as harsh as the mixer drum, it has a lid on as well, keeps in the dust and makes a lot less racket.
Have you ever tried Muriatic acid baths?
