Small Part CNC Plasma Cutting Fixture
msimpson99
Post by msimpson99 »
This is my second generation Small part plasma cutting fixture.
The heart of the fixture is the support bracket. Here is a little video I made making one of the brackets and testing the fixture.
https://youtu.be/Qb1a3cxCT9w
The fixture supports both flat stock and angle as shown here.
The full write up can be found here.
http://www.kronosrobotics.com/cnccsplasmafixture
Re: Small Part CNC Plasma Cutting Fixture
NIce fixture, looks like it could be handy to have for cutting small parts as shown :)
Ironken
Post by Ironken »
Very slick! I built a fixture in my table (not nearly as pretty and way bigger) to cut profiles in angle and sq/rec tube. Once I trammed it in, I seldom drill anymore. About half of the work I do on the cnc is tube and angle.
msimpson99
I called this one the "Simple Plasma Fixture" because I am planning a more advanced one.
I have harmonic drive I purchased specifically for the plasma machine. It is my goal to create a fixture that I can mount my steel angle into so I can mill both sides in one job.
msimpson99
I have added a couple small parts to the fixture to help with securing the stock.
These are probably some of the smallest parts I have made with my plasma cnc. I am very happy with the results.
Here is a little video of the process.
https://youtu.be/qrV5DekQHeM
These were cut with my everlast 50s on a CNCCS machine with Harbor Freight 40Amp consumables. I cant wait to try cutting them out using my Hypertherm machine using finecut consumables.
I added the holding arms to my writeup (near the end) here:
https://www.kronosrobotics.com/cnccsplasmafixture
Mtw fdu
Post by Mtw fdu »
That is a really cool fixture. 8-) 8-) 8-)
Mtw fdu.
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
slick looking tool, you are having to much fun remember it is a workshop, not a fun house :HaHa :Yay
