QCAD to Inkscape
QCAD to Inkscape
I bought the full version of Qcad quite a while ago to convert DXF files to SVG files to be able to edit in inkscape. Lately I have been having an issue when opening in inkscape, the lines look all connected, but when I click on them, it is many smaller lines. I would like to be able to have it a solid image that I can use the "difference" command to be able to cut it out of different (larger) shapes. Is there anyway to fix this?
Re: QCAD to Inkscape
This may not work but if you take the cursor and put a box around the whole drawing and then go to path and hit combine, then save it.
The box is not a boarder around but a way to highlight all the parts of the original drawing. here is a test I just did to check it out.
I'll give it a try! Thanks for helping me out...again...and again!
