wavy cuts
james.davis
wavy cuts
Post by james.davis »
http://www.plasmaspider.com/download/fi ... w&id=54117
Can any one tell me why my cuts look like this?
I have a DHC2 WITH DESIGNEDGE SOFTWARE ,RUNNING A HYPRETHERM 45,NEW CONSUMABLES.at speeds 300 to 340 same results amps 45
lots of drose on back.
Jim
Re: wavy cuts
Possibly travelling too slow and or slop in your machine motion could cause this.
Re: wavy cuts
What is the material thickness and type? What is your acceleration set at? Do you have advanced height?
Jim Colt Hypertherm
Gamelord
4.5 Star Member
4.5 Star Member
Re: wavy cuts
Post by Gamelord »
Slat wave most likely. All the wiggles are in the same spot, right after a gantry turn. When the gantry changes direction abruptly it shakes the table, causing the slats to wave giving you wiggly cuts. Either that or one of your drive motors is slipping or loose, giving the same thing. I had this exact thing when I first started and found my slats were wiggling.
Mesmetalart
Re: wavy cuts
Post by Mesmetalart »
Gamelord wrote: Sat Apr 14, 2018 2:31 am Slat wave most likely. All the wiggles are in the same spot, right after a gantry turn. When the gantry changes direction abruptly it shakes the table, causing the slats to wave giving you wiggly cuts. Either that or one of your drive motors is slipping or loose, giving the same thing. I had this exact thing when I first started and found my slats were wiggling.
Just interested. How did you stop the wiggling
ben de lappe
Re: wavy cuts
Post by ben de lappe »
Had the same basic thing at one time, took me a bit to figure out back then but my experience was similar to Gamelord's. My machine was TM3 finished 5'x10', "bolt together". I found running fast cut speed on pieces with hard turns etc. would cause the exact same looking waves. I combed the machine over looking for any sign of unwanted movement and tightened as needed also making adjustments to speed/ramping rates. Seemed to alleviate my issue for the most part until I was hit by belt stretch on one Y axis motor...waves again... :roll:
Gamelord
4.5 Star Member
4.5 Star Member
Re: wavy cuts
Post by Gamelord »
I stopped the slat wave by welding in another notched third "center" finger to hold the slats and put a slight bend in them so the slats were under a little tension instead of just sitting in the table free. Fixed the issue right up.
