Ohmic sensor wire?
Jeffery
Ohmic sensor wire?
Post by Jeffery »
Hi my name is Jeff. Today I broke a wire on my dhc2 plasmacam. It connected near the torch tip on one end and on top of a motor? This caused my torch to hit my material several times. I spliced the break and it would still repeat the same outcome when ready to cut. Where can I get a new wire or get this one fixed. Any suggestions would be greatly appreciated.
Re: Ohmic sensor wire?
Must be a break in your wire between the ohmic clip and your controller somewhere else unless your spice was a bad connection. Ohmic sensing is a simple single wire setup. Follow that wire back and solder and seal any breaks.
harrymorley
Post by harrymorley »
is there a 47k ohm resistor in that lead ? I just broke the wire on that resistor and replaced it...works great now
Jeffery
Post by Jeffery »
Is that a very small inline fuse link?
Francisco
Post by Francisco »
Looks like a fuse link, but it's not. It's a small (1/2 W?) 47k Ohm resistor, as harrymorley pointed out.
Jeffery
Post by Jeffery »
Where do I get a new one
Jeffery
Post by Jeffery »
Thanks for all the support. I'm honestly very grateful harrymorley and Francisco.
harrymorley
i ordered them online ...got 10 for really cheap...minimum order
