Here is a Snoopy mailbox topper that I recently did for a friend. The original DXF file was created by Stan at DXF Graphics. Permission was given to share on this site since it's not a graphic that he normally sells on his site. I hate that my first share is not a file that I actually created but at least I was a small part of the original idea.
If you plan to cut and use for a different type of project, you will need to ad his ear(s). I asked Stan to leave it off because my friend was going to paint the ear on each side of the mailbox. I took a picture of it before he had a chance to do that. He also mentioned possibly using some vinyl to make ears so they could flap around in the wind. Everything was made using 14 gauge including the brackets that I bent and welded up. The Snoopy was scaled and cut at approximately 14 inches long for the mailbox that it was mounted to.
Snoopy Mailbox Topper.svg
You currently do not have access to download this file. To gain download access for DXF, SVG & other files Click Here
LDR 4'x4' Water Table
Command CNC Linux Controller
InkScape / SheetCam
