xbox controler
xbox controler
I am trying to set up an xbox controller on my table but so far I can not get it to work. the computer sees it and I have the plugin installed and active but still will not work. In the bottom left corner of the config screen there is a box that says controller with found and none inside the box. None is selected and the box is grayed out. Is this the problem if so how would I get the box to be not grayed out? This is with CandCNC Ethercut. I will buy the PN200 but at this time I cant afford to spend the money on it.
- Oldsarge
Re: xbox controler
http://www.ebay.com/itm/Handheld-2-4G-M ... 1e898c7873
Use mine constantly and I love it... Works seamlessly with XP and you can't beat the price... comes with a charging cable and I have to charge mine up once a week or so depending on how much I use it. Has internal batteries.
You don't have to hold any function keys to do anything including raise/lower the Z and the mouse touchpad actually works!
Oldsarge
Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
- WyoGreen
Re: xbox controler
I use a wireless XBox 360 controller on my candcnc ethercut, and it works fine. I use a Mach3 plugin from the Mach3 website. The attached PDF gives quite a bit of help.
Router
Laser
Router
Laser
Re: xbox controler
That's interesting, I've never seen one of those, guess I never looked. I would assume it just acts like a regular wireless keyboard just smaller so no setup needed?
- _Ogre
Re: xbox controler
is your xbox controller microsoft?
do you have Xbox360_32Eng.exe loaded?
is there the correct quadrant light lit up?
other than loading gcode into mach3 the xbox controller is the only thing i touch
not sure how people run a table without it
i have ours configured to:
turn on laser x-hairs
control a,x,y,z axis's
zero x,y,z axis's (no a axis zero needed)
coolant on/off
start/stop program
rewind gcode
coolant on/off
start/stop program
rewind gcode
an ogre smiley how cool!
Re: xbox controler
I'm not sure if it Microsoft or not, does it need to be? I stole it from my nephew, he said it was new but that's about all I know about it. It does have the top left quadrant light come on and if I hit the center round button the help window comes up on the screen but nothing else does anything.
- WyoGreen
Re: xbox controler
The plugin supports the Microsoft Xbox360 Controllers. If you have a different one, then you have to go to the config screen in Mach3 and change the VendorId and ProductID of the controller you do have.
Router
Laser
Router
Laser
Re: xbox controler
I see that makes sense now. I will check it out and let you know.
Re: xbox controler
You may face dueling plugins. We have never tried an Xbox USB controller and that plugin runing with the ESS plugin and the EtherCut plugins. I have no clue if the MACH xbox plugin will work. Even though you don't have the PN200 the hooks are still there in the c3Bus 4 port USB to RS485 to talk to the internal commands in MACH.blackandtan wrote:I am trying to set up an xbox controller on my table but so far I can not get it to work. the computer sees it and I have the plugin installed and active but still will not work. In the bottom left corner of the config screen there is a box that says controller with found and none inside the box. None is selected and the box is grayed out. Is this the problem if so how would I get the box to be not grayed out? This is with CandCNC Ethercut. I will buy the PN200 but at this time I cant afford to spend the money on it.
TOM C
Re: xbox controler
I was skeptical. Of coarse I ordered it and it functions,surprisingly well.Oldsarge wrote:http://www.ebay.com/itm/Handheld-2-4G-M ... 1e898c7873
Oldsarge
Awesome! Anyone have an idea how I can set a hot key to toggle THC in mach?
Re: xbox controler
I just got around to checking an X box controller with the MP3100 DTHC-IV the wired one worked but the wireless did not.
I only checked the axis movement no other functions.
Re: xbox controler
I also have the same mini keyboard that Oldsarge has. I have my normal keyboard and mouse at the computer and this plugged in at the same time. It works perfectly and is very useful in all aspects of CNC control.
Scott
Scott
Re: xbox controler
I would like a hot key shortcut as well for THC off/on. Any thoughts Tom?
Scott Sutton
Scott Sutton
- Oldsarge
Re: xbox controler
I may be wrong, but I believe to have a hotkey set up in Mach you have to go into a screen designer program like the ones shown here: http://www.machsupport.com/software/dow ... creensets/ And you assign a hotkey to a button in the designer.
I downloaded all the files to use the screen designer, but I just don't have the time to take on the learning curve and the many hours it would take to design and tweek the screens....
Oldsarge
Oldsarge
Re: xbox controler
I use a Generic X-Box 360 Controller with my Ethercut Bladerunner there is a conflict with Scanything when the X-Box Controller is plugged in. I downloaded the plugin from MACH SUPPORT... X-Box Schilling... Works fine.
When time and money permits I will probably order up the Hand Wheel from CandCNC...
But for now my X-Box Jog Box works fine.
Re: xbox controler
The DTHC IV has no THC button in MACH (to turn the MACH3 THC on.off.) because it does not use it. The DTHC ON/Off button can probably be called if you can figure out how to toggle a screen (OEM) button via the USB driver link
You need to be aware that the DTHC IV on/off is dynamic from the g-code, meaning it self-toggles ON at the beginning of each cut and OFF at the end so if you do have the control of the button you either need to be in Manual Mode or be ready to use the button on every cut.
There are some pretty powerful options in the latest POST DTHC-HYT-TAP_SoftPierce+Marker-rev11D.scpost . One in the Operations window in SheetCAM is "Min cut length for DTHC ON" If you are cutting something (like small holes or short lines or smaller shapes) just put in a number greater than the total length of the cut and anything shorter than that will automatically leave the DTHC turned off. No Cut Rule needed
Even in older models running with the parallel port and that DO use the internal MACH THC you will find that turning it on or off during motion will cause a pause in the motion and you will get a bad divot or on thinner materiel lose arc ok and it will stop.
There are several ways to control the DTHC ON/Off from code.
The latest Updated drivers and firmware will be posted today. The announcement and links will be a Special Announcement on the support form and on the manuals page of the website
Re: xbox controler
Thc,or dthc whatever you want to call it. I need to manually turn it off before my first pierce, as the torch will not start travel with it "on" . I've tried setting delay times, min cut lengths and also cut rules. Still can't run a program without toggling it off to begin a cut. Torch fires and pierces, no other motion will happen.
Re: xbox controler
I’m using a Xbox controller as well with CANDCNC parallel set up and I’m wondering if you can assign buttons to adjust volts. Anyone have any ideas?
Re: xbox controler
Troy you should be able to write a macro in MACH that lets you set a value in the Preset DRO (PEM DRO) using the screen builder. YOU will probably have to just assign the UP and DOWN "bump" buttons in the THC section because DRO;s need a number pad to do an entry
Re: xbox controler
You should not have to turn off the DTHC beacuse in code it not on until the Z moves from pierce to cut height . DTHC is dynamic control codes to turn ot on and off. If you have a DTHC !! or DTHC IV then there are specific S codes it understands to turn the DTHC on on off , After it turns on you can set a DTHC delay that stops it from moving the Z until after that time expires. Depending on the age of the system and the length of your trrch hose you may need to add in a macro that holds motion until the ARC OK goes active. If the problem is that it refuses to move then you are not getting Arc OK at the beginning.
Re: xbox controler
Ok thanks, that is beyond my knowledge so I will need to start a course on YouTube University I guess.tcaudle wrote:Troy you should be able to write a macro in MACH that lets you set a value in the Preset DRO (PEM DRO) using the screen builder. YOU will probably have to just assign the UP and DOWN "bump" buttons in the THC section because DRO;s need a number pad to do an entry
Re: xbox controler
To do numbers you have to have a keyboard entry. Button pushes are pretty easy.
Re: xbox controler
We have used Xbox plug in on CandCNC hardware for 6-7 years. It worked great in all the forms. However we integrate the PN200 on all our CandCNC driven Star Lab machines which is superior in almost every way to an Xbox controller. The PN200 has hundreds of functions. The Xbox controller has as many as there are buttons. It is limiting. The Xbox controller should be examined as the minimum controller for use while the PN200 should be tried at least one. You will quickly learn how much better the PN200 is.
Re: xbox controler
I would buy a PN200 in a heartbeat if it didn’t have a cord. The wireless aspect of the 360 controller is hard to beat but I am still considering the PN200. I just want to assign 2 buttons to raise or lower arc voltage but will need to learn Mach3 screen designer in order to do so.BTA Plasma wrote:We have used Xbox plug in on CandCNC hardware for 6-7 years. It worked great in all the forms. However we integrate the PN200 on all our CandCNC driven Star Lab machines which is superior in almost every way to an Xbox controller. The PN200 has hundreds of functions. The Xbox controller has as many as there are buttons. It is limiting. The Xbox controller should be examined as the minimum controller for use while the PN200 should be tried at least one. You will quickly learn how much better the PN200 is.
Re: xbox controler
I'm wondering how you handle the auto power off function on the wireless Xbox controller. I thought a wireless controller would be handy, but mine powers off after a time with no activity and crashes Mach3. Then I have to restart to get it to function again. I have not been able to find a way to disable this.
