Duck Hunter Welcome Sign
Statelinetruck
Post by Statelinetruck »
I'm needing a dxf file of this sign does anyone out there have this file thank you in advance
metalmayhemdesigns
Re: Needing dxf file
Post by metalmayhemdesigns »
Try This :D
Duck Shooter Welcome.dxf
Cz_apie
Post by Cz_apie »
Thanks for sharing, nice clean file
Deon
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
Countrylane
Post by Countrylane »
Thanks for the dxf file on this. I like the font on welcome!!
Largemouthlou
Post by Largemouthlou »
Nice!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
david jordan
Re: Duck Hunter Welcome Sign
Post by david jordan »
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
hdfaster
Post by hdfaster »
Thank you!
Rita Chuck
Post by Rita Chuck »
Thanks for the file!
Nice file! Here it is scaled to inches from metric.
Duck Shooter Welcome scaled to inches.dxf
Rickzink
Post by Rickzink »
Im trying to download this file as I have a custoemr that wants this cut. When I try to open in inkscape it gives me the following error:
30 entities of type polyline encountered and ignored. Please try to convert to release 13 format using qcad.
What the heck does that mean and can someone tell me how to do it?
ROKCRLER
Post by ROKCRLER »
Rick,
Try these
I opened them it in QCad and saved as DXF14 and SVG.
Opened in Inkscape and ungrouped, selected all the internal pieces and combined, then selected the outside and differenced. Make sure the outside graphic is at the bottom of the stack.
Duck Shooter Welcome.svg
4x8 Dynatorch
PM85
~Mo~
Rickzink wrote: Tue Jul 18, 2023 4:47 pm Im trying to download this file as I have a custoemr that wants this cut. When I try to open in inkscape it gives me the following error:
You are using an older Inkscape version which did not allow import of DXF R14 file format. I would recommend downloading and installing the latest Inkscape version 1.2.2 which will directly open/import DXF R14 files.
