Cutting into a water pan with a hand torch
enzed
Post by enzed »
Would it be dangerous for the operator to manually cut sheet metal resting on the ribs of a water pan using a hand torch (Hypertherm T45V torch)? Also, could the torch be damaged by the water splashing onto it?
enzed
Re: Cutting into a water pan with a hand torch
Post by djreiswig »
I do it without issue other than getting a little wet.
enzed
Post by enzed »
Hello djreiswig,
Thank you; I am pleased that this can be done safely as this option increases the versatility of the machine.
Regards,
enzed
