It is currently Tue Oct 16, 2018 9:48 pm
Problem, please help
Have a question and don't see your manufacturer? Post here and if we get enough action on that manufacturer we will add a forum
DesStorm
Postby DesStorm » Fri Mar 23, 2018 2:19 am
Hi
I'm new to plasma CNC. Previous employee just up and left so I've been thrown in the deepens. Everything has been going well, been cutting mild steel, aluminium and stainless steel in various thicknesses.
Suddenly yeaterday mid-cut the plasma head started lifting away from the cutting surface, still arcing but about an inch above surface.
Went through process of replacing electrode, tip and swirl ring. Cleaning sensors and water traps. Shut down system and restarted everything. Tried different cut files and different metals.
Torch pierces metal and then lifts one inch away from surface over the next 2 inches of cut.
Using:
Hypertherm Powermax 105
FangLing F2100B
HYD XPTHC-100 III
I know it isn't great equipment, but it is what we've got.
Thank you
sphurley
Re: Problem, please help
Postby sphurley » Fri Mar 23, 2018 8:38 am
You do have the plasma return cable connected to the material?
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
ScottF
Postby ScottF » Fri Mar 30, 2018 9:19 pm
Sounds like a torch height control issue. Could be several things causing it. Check to make sure that the return cable is hooked up. Check to see that the cable that attaches to the torch shield is hooked up check the voltages on your control software, it might just be set wrong. I would start there and if those things don't fix the issue either check with the manufacturer or try back here. Either way please let us know! Best of luck.
I don't have all the answers but I do have a lot of opinions....
ShopSabre Sidekick 8 with water table
Hypertherm Powermax 85 w/machine and hand torches
IR 5hp 60 gal,+ 60 gallons of storage and aftercooler
Lincoln Square Wave 200
14x40 lathe
