It is currently Fri Oct 19, 2018 9:37 am
Cutting Galvanised with finecuts
SeanP
Postby SeanP » Mon Mar 19, 2018 5:53 pm
Doing great with the finecuts, but having a bit of trouble on galvanised on longer cuts with slag build up on ohmic shield.
I'm cutting at slightly above book height at 1.8mm, just wondering if there is any advise out there to stop this other than maybe using the un shielded version?
Sean
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
abmetal
Re: Cutting Galvanised with finecuts
Postby abmetal » Tue Mar 20, 2018 8:04 am
I have the same problem. I use nozzle dip by just coating the bottom of the shield and also spraying the sheet with anti spatter. It helps but doesn't eliminate the problem. By doing that, a lot of the "debris" rolls out from under as it's cutting but will still eventually build up anyhow. I can occasionally cut a half sheet of artsy stuff without any problem and other times it seems like I spend more time cleaning than I do cutting. One thing that impresses me about galvanized steel though is how clean it cuts...no dross whatsoever.
Allen
SeanP
Postby SeanP » Tue Mar 20, 2018 8:19 am
Thanks Allen, never thought of the nozzle dip for that, I use it on 45a parts as well.
Trouble is I possibly have a job coming up with 150 parts 600mm x 400mm to cut, need to find something, don't suppose the un shielded version would have this problem, but could do with using ohmic on 1.5mm thickness.
Table build gallery
abmetal
Postby abmetal » Tue Mar 20, 2018 8:28 am
I've used the unshielded 45amp and it works ok but I've found it just doesn't cut detailed artsy stuff like the finecut.
We get 16g galvanized drops free from a local hvac business so that's why we use it.
Allen
SeanP
Postby SeanP » Tue Mar 20, 2018 9:11 am
It's the finecut without the ohmic sheild I was meaning, is that what you used?
Wondering if I couldn't just add a leg to the 220955 deflector for ohmic sensing.
Table build gallery
abmetal
Postby abmetal » Tue Mar 20, 2018 9:45 am
I use the 45a finecut nozzle (220930) with the 45a finecut shield (220948). I have used the 45a nozzle (220941) with the 45/65a shield (220817) but I don't think the detailed cuts look quite as good.
Allen
SeanP
Postby SeanP » Tue Mar 20, 2018 10:21 am
Thought this was worth a try!
From what I have done so far it looks perfect, 150 parts will give it a good test though :lol:
It's a 220817 shield cut down and a bit of tig rod inserted.
Table build gallery
abmetal
Postby abmetal » Sun Mar 25, 2018 11:42 am
Sean, how's your modified shield working on the galvanized?
Allen
SeanP
Postby SeanP » Sun Mar 25, 2018 4:55 pm
Definitely a lot better than the standard ohmic shield, I still think it can be improved further though, might not have taken enough off the old shield yet, could thin down the leg a little as well.
I know the finecuts are used a lot for galvanised, wonder if they use the ohmic shield? (Jim) ;)
Table build gallery
SeanP
Postby SeanP » Mon Apr 02, 2018 5:50 pm
It works great on stainless as well especially with cut height being so low.
Table build gallery
beefy
Postby beefy » Tue Apr 03, 2018 2:38 am
Does nobody do planned mid cut stoppages to clean the nozzle shield.
I'd insert bits of code to bring the torch to a specific position with Z raised up high. Better of course to not need to do that.
8 x 5 water table
Powermax 1250 with Duramax torch
UCCNC controller, UC400-ETH & UC300-ETH motion controllers.
Geomagic Design 3D solid modelling
Coreldraw X5
SeanP
Postby SeanP » Tue Apr 03, 2018 5:46 am
I normally just hit space bar Kieth when that's needed, was struggling to run through one part on galv as it was, stainless was tricky enough as well, cured it now though.
Table build gallery
dixonsweden
Postby dixonsweden » Sat Apr 28, 2018 2:58 pm
I cut galvanised steel with book spec for finecut steel , works exelent. Almost no dross at all on the backside of the parts. I dont have that sheald tho. I have one that the whole tip of the nossle is exposed.
For me i rather cut galvanised than standard.
SeanP
Postby SeanP » Sat Apr 28, 2018 6:17 pm
dixonsweden wrote:I cut galvanised steel with book spec for finecut steel , works exelent. Almost no dross at all on the backside of the parts. I dont have that sheald tho. I have one that the whole tip of the nossle is exposed.
Yes that's probably the safest one to use on galv, without use of the ohmic though :(
Been cutting quite a bit of 2mm steel with the fine cuts recently, cut quality is superb, next to no dross at all, not arty stuff mind you, even on hot rolled steel you have to keep an out for a small bead of slag building in front of the standard ohmic shield, it's not bad though.
Table build gallery
