Cannot connect to update server error
edclayton1
Post by edclayton1 »
Anyone know why most of the time I cannot use the SheetCam update feature. Attached is the dialog message that I get when I try to update my SheetCam. Then once in a while when I simply open SheetCam it decides it wants to do an update. Otherwise how can I update my system without losing all my settings is another question I would like to ask? Especially if that computer is not connected onto the internet. :o
Home Built 4 * 8 table
Bladerunner
Miller Syncrowave 250 TIG welder
Miller 211 Wirefeed Welder
Bridgeport Mill
Jet 13 * 40 Lathe
Hypertherm Powermax 65
80 gal 2 stage 175 PSI Emax air Compressor
Re: Cannot connect to update server error
Post by djreiswig »
Just download the file from the site and install it. I've done this a few times on my non-internet connected computer and it doesn't lose the settings.
edclayton1
Thanks I will give it a shot now. I appreciate the info. Cheers,
Bladerunner
Bridgeport Mill
Jet 13 * 40 Lathe
Post by tcaudle »
Down load to memory stick and copy file to SheetCAM PC unzip and run the installer. It sees older versions and does not change the settings.
If its a LINUX system follow the instructions on the ShhetCAM downloads page for the Linux version. You can also get details on the CandCNC Support Forum.
Return to “SheetCam”
