Cut paths are not cutting all the way
mimcustoms
Post by mimcustoms »
My cut paths are not cutting all the way so pieces are not falling out?
Scratch
Re: Cut paths are not cutting all the way
Post by Scratch »
Gonna need more info than that...
Plasma cutter, amperage, tips, speed, type of metal, thickness, software used, table brand, color of underwear, torch height... Stuff like that.
mimcustoms
Plasma cutter, 45 amps, Hypertherm, z-104.5, pickeled and oiled 14 gauge, Design Edge, Plasma Cam, 0.06.....and Life is to short to wear underwear.
Bobkovacs
Post by Bobkovacs »
What is your overcut set to on the cut paths? How "short" are you coming up on the cuts- is it just a tiny bit left, or are they stopping an inch short of the end of the cut?
mimcustoms
Was not clicked, but now clicked and at 0.04 on both min and max
mimcustoms
It was just a little short so we are grinding now and will try next
mimcustoms
Well, that did not work! What do I try next?
