Good afternoon!
I've been lurking on this site as a mostly silent member for at least 8 years now. I'm a high school shop teacher in Appleton, WI and have a 9 year old DHC2 in my welding shop. My machine has worked pretty much flawlessly until just recently when I started to experience the torch not maintaining cut height and running into the material causing an error. I tried many different things with no luck but I admit I'm not expert. Finally, I called PlasmaCAM and ran into the hot topic on this forum that they no longer support the older machine and recommended the software upgrade. I don't have that kind of money in my budget so upgrade is not a possibility. I got the feeling the tech guy knew what the solution was to my problem but he couldn't tell me. Anyway, in order to continue offering students access to this technology I need to fix this problem to get my machine back up and running. Any suggestions or help would be greatly appreciated!
Tom
PlasmaCAM Z axis drift - HELP!
- rdj357
Re: PlasmaCAM Z axis drift - HELP!
Tom,
When I had that problem it was a stuck button on the keypad. If you have a diagnostics window that you can open in the software you can look to see if the Z down button is steady or flashing yellow when it is not being pressed. If so the replacement is only 89 for the keypad.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
