I cut a railing insert for a friend using a wilderness scene that I found online and made a bunch of changes such as adding the mountains, adjusting trees to comply with the 4" space code, eliminating sharp corners, etc. The plan is to use barn wood for the newel posts and weld 1.5x1.5 tubing top and bottom for mounting.
The small piece is 35x33 and the large piece is 82x33.
The small one took about 15 minutes and the large one took about 45 minutes (16,500 lines of code). I am sure that I can get those times lower because my safety plunge height is around 2", so on every pierce the z-axis moves down slowly from 2" above the metal.
I was not able to cut them both at the same time, I just put them on the table after both were cut to get a picture.
Homebrewed plasma table in the works, NSK linear rails, 3.2:1 belt reduction, CandCNC Plazpak 1A with DTHCIV Ethercut, Hypertherm 85, CommandCNC and SheetCAM
Click here for build post
