Weld Jig
Daddude
Weld Jig
Post by Daddude »
Here is a weld jig I put together. Have had some interest in it.
weld jig.dxf
VPT
Re: Weld Jig
Post by VPT »
Thank you!
david jordan
Re: Weld Jig
Post by david jordan »
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Old Iron
Re: Weld Jig
Post by Old Iron »
Thanks for sharing!!!!!!!!!!!!!!
nalin400m
Re: Weld Jig
Post by nalin400m »
Thanks, looks great
Nalin Manufacturing, LLC
Hypertherm Powermax 85
Bulltear Starlab 4'x8'
Daddude
Re: Weld Jig
Post by Daddude »
Here's mine before clean up.
Metal Works
Re: Weld Jig
Post by Metal Works »
Thanks for the share What size metal did you use
Daddude
Re: Weld Jig
Post by Daddude »
.25 inch steel
BILLETMAN
Re: Weld Jig
Post by BILLETMAN »
thank you !
towman1002
Re: Weld Jig
Post by towman1002 »
thats awsome.ive been wanting to build a table just hadnt had time.thank you
BearFab
Re: Weld Jig
Post by BearFab »
Thanks for sharing
ETCWeld
Re: Weld Jig
Post by ETCWeld »
Thank you for this
techno
Re: Weld Jig
Post by techno »
Thank you.
Robert
Re: Weld Jig
Post by Robert »
Looks great
Harperbenji
Re: Weld Jig
Post by Harperbenji »
Thanks Just starting out and this will help
reklez2010
Re: Weld Jig
Post by reklez2010 »
Great Share Thank you
tylerd
Re: Weld Jig
Post by tylerd »
Daddude wrote:Here's mine before clean up.
Was that cut with plasma?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
Daddude
Re: Weld Jig
Post by Daddude »
Yes
mardybum
Re: Weld Jig
Post by mardybum »
Thanks for sharing
