It is currently Tue Nov 20, 2018 3:30 pm
Harbour Freight powder coat guns
OTHill
Postby OTHill » Wed Dec 13, 2017 11:08 am
Hi.I'm using HF gun and getting by. Big problem still is barrel filling with powder and puking it out. Any suggestions? I have modified it to use Mason jars but still no difference.
Re: Harbour Freight powder coat guns
Postby acourtjester » Wed Dec 13, 2017 5:33 pm
the way it works is the power is to fly around inside the jar and slowly go into the barrel. If you have the jar to full it forces the power out way more them it should. Try reducing the amount of power in the jar.
Everlast PM 256 tig
Jarett
Postby Jarett » Wed Dec 13, 2017 5:43 pm
When using the regular plastic containers for the gun I only fill mine about 1/4 full. Any more powder and it blows to much out.
OTHill
Postby OTHill » Wed Dec 13, 2017 9:26 pm
It will even do it when the jar is almost empty.
Probird
Postby Probird » Thu Dec 14, 2017 9:05 pm
Very poor design, had one when I first started powder coating and it would do the same thing. Ended up taking it apart and sharpening the cross sections at the tip, worked better but still sucked. Bought a spectracoat gun and it works excellent, not a production setup, but sprays out fine and is going on 4 Year’s without a hiccup.
Try turning your pressure WAY down and have someone turn it up slow until it sprays better, if I remember correctly, it takes really low pressure or it blobs out really bad.
4x8 Premier Plasma Table
Hypertherm 45xp
Inkscape
Viacad
Mach3
Proma 150 THC
Gamelord
Postby Gamelord » Fri Dec 15, 2017 12:43 am
Usually a pressure issue. You only need barely any air pressure. Usually 10-12 psi and your air needs to be very very very dry. any moisture and it will blow chunks.
OTHill
Postby OTHill » Fri Dec 15, 2017 11:21 am
Thanks all guess I should go looking for a new gun.
Granite
Postby Granite » Sat Jan 06, 2018 4:13 pm
In addition to keeping pressure low at your regulator, and no more than 1/4 full jar, adjust that brass knob at the base of your gun handle, to its minimum. Mine is super sensitive but that knob adjustment has fixed most of my problems.
Return to “Powder Coat”
