It is currently Sun Oct 21, 2018 4:26 am
Mk3 Diy breakaway torch mount
SeanP
Postby SeanP » Sun Dec 03, 2017 4:56 pm
Had to go a little bigger for the new Duramax torch so had a rethink.
Easy enough to make up, you just need 3 x 12mm bearings and 2 magnets (I cut one in half)
Bearings tig welded in, magnets stuck with double sided tape.
Torch clamps I used 10mm and 5mm for the plates.
I can post detailed info & dxf if anyone wan'ts them.
Duramax torch clamp.DXF
Breakaway torch mounts back plate.DXF
Breakaway torch mount plate.DXF
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Scratch
Re: Mk3 Diy breakaway torch mount
Postby Scratch » Sun Dec 03, 2017 8:05 pm
Nice and simple... I like it!
beefy
Postby beefy » Mon Dec 04, 2017 3:48 am
Thanks Sean,
I think I'll be using this principle when I make my breakaway. Cheap, easy and looks effective.
Who needs to pay $300 for a breakaway.
Keith.
8 x 5 water table
Powermax 1250 with Duramax torch
UCCNC controller, UC400-ETH & UC300-ETH motion controllers.
Geomagic Design 3D solid modelling
Coreldraw X5
Postby acourtjester » Mon Dec 04, 2017 7:50 am
Looks like the old "KISS" process still works, very nice I'm sure it will be copied.
Are you going to put a disconnect switch with it?
Everlast PM 256 tig
SeanP
Postby SeanP » Mon Dec 04, 2017 8:00 am
acourtjester wrote:Looks like the old "KISS" process still works, very nice I'm sure it will be copied.
It's about time I did, I've had 2 leaks in the tray due to knocked off torch using previous design :lol:
Yes it works really well, better with the bigger bearings, took a bit of playing around with getting right hole size and magnet position, I'll edit post with details soon.
Table build gallery
Postby acourtjester » Mon Dec 04, 2017 8:05 am
I your a good man Gunga din :D
Everlast PM 256 tig
SeanP
Postby SeanP » Mon Dec 04, 2017 8:10 am
Had to google that one :x :lol:
Table build gallery
Postby acourtjester » Mon Dec 04, 2017 11:32 am
Showing my age again :o :lol:
Everlast PM 256 tig
steel 35
Postby steel 35 » Mon Dec 04, 2017 12:16 pm
Those clamps cut out very nice, & the whole package is sweet.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
Euclid933
Postby Euclid933 » Mon Dec 04, 2017 1:25 pm
Looks great. I'm looking at upgrading my table, it uses a set of ball bearings to run on the plate and a pneumatic ram to lift the torch.
I'd like to change it to something like yours, with THC. Just not sure what to go for at the moment.
I've had a couple of torch collisions over the years, really like your idea.
Will.
SeanP
Postby SeanP » Mon Dec 04, 2017 3:47 pm
More info added to post and dxf files for parts.
Table build gallery
Euclid933
Postby Euclid933 » Tue Dec 05, 2017 2:18 am
Thanks Sean.
Postby acourtjester » Tue Dec 05, 2017 12:19 pm
thanks again
filed away to due when I get home
Everlast PM 256 tig
david47julie
Postby david47julie » Sat Dec 09, 2017 11:07 pm
Thanks, that is a great idea I have been thinking about building one but I had not come up with a good idea yours looks great! Thanks again.
Greg_R
Postby Greg_R » Sun Jan 28, 2018 11:40 pm
Greg_R
Postby Greg_R » Sun Jan 28, 2018 11:45 pm
[quote="Greg_R"]I accidently found a youtube video of shapes you make using magnetic balls. It may take some experimenting with placement, but that would knock out 2 birds with one stone. I don't have a torch set up yet, since I am in the planning stages.
I could make this my first cut, but if something goes wrong during setup...
Would anyone mind selling me the metal cut outs?
Edit: that link is not magnetic balls...
Greg_R
Postby Greg_R » Sun Jan 28, 2018 11:52 pm
Greg_R
Postby Greg_R » Sun Jan 28, 2018 11:53 pm
I'll go with the square magnets like you did. Do you mind telling us the size and strength of the magnets? There are all kinds of strengths.
Greg_R
Postby Greg_R » Mon Jan 29, 2018 12:06 am
Edit: that link is not magnetic balls...[/quote]
Greg_R
Sorry don't know what's wrong with the forum and the double posting when editing.
SegoMan DeSigns
Postby SegoMan DeSigns » Mon Jan 29, 2018 11:52 am
Nice design,
You could add tabs to the torch mounting piece to hold some alignment lasers as well. The ones on fleebay require a 1/2" hole.
SeanP
Postby SeanP » Mon Jan 29, 2018 6:36 pm
Have a look on that drawing Greg, the magnets I used are 19x 29 with one cut in half for the top two, been using it for a while now and it's spot on, very easy to lift off and re-locate, just the right hold.
Na don't bother with the mag balls, be a right pain welding those on! :shock: :lol:
Table build gallery
SeanP
Postby SeanP » Mon Jan 29, 2018 6:37 pm
SegoMan DeSigns wrote:Nice design,
Good idea, I really would find those useful :!:
Table build gallery
trtilton61
Postby trtilton61 » Mon Jan 29, 2018 7:37 pm
Thanks,great looking set-up.
Precision Plasma HDSE-4x8
CandCNC Bladerunner dragon cut
Hypertherm 65
Mach3
sheetcam
Greg_R
Postby Greg_R » Mon Jan 29, 2018 9:45 pm
SeanP wrote:Have a look on that drawing Greg, the magnets I used are 19x 29 with one cut in half for the top two, been using it for a while now and it's spot on, very easy to lift off and re-locate, just the right hold.
Yes I did see the size of the magnets after posting that. Thanks so much for sharing!
