Hi everyone
Just a quick request / comment
I have this year changed from the original PM45 to the new PM45XP, I have noticed a couple of things that stand out and I am asking for comments from others who have also changed to the new XP machine just to get a feel if it is just my set up or is it a more common experience
I have noticed that the cooling fan within the XP machine comes on quicker and more frequently than the older 45 I do not see this as a negative but just concerned that it is different than what I know (so far)in comparison.
I am also seeing a difference in the voltage settings of around 10v higher from the PM45 to the 45XP to maintain the correct cut heights, I have the XP voltage divider ratio set at 50:1 (factory preset voltage divider)as was my original PM45
So if you have made this change from PM45 to PM45XP as well then please add you comments or additions and maybe Mr Colt would like to comment and confirm any of the above just to help clarify and put our minds at rest
Apart from the above concerns the new XP is great and I am glad I invested the £ to make the change to have the RS 485 connection to work with the CandCNC kit
One more request but for SheetCam users, I have tried to edit the "PLASMA TOOL" where it states "Tip size - amps" but it always seems to defaults back to 45 has anyone else noticed this
Hypertherm 45 to a 45XP
- exapprentice
Best Regards to all
Exapprentice
(Pete)
10'x5' DIY table / PM 45XP + M/C Torch - Trying to add 4 axis Tube cutting
Exapprentice
(Pete)
Re: Hypertherm 45 to a 45XP
exapprentice wrote:Hi everyone
I have noticed that the cooling fan within the XP machine comes on quicker and more frequently than the older 45 I do not see this as a negative but just concerned that it is different than what I know (so far)in comparison. The 45 XP produces a higher wattage output than the original Powermax45, this is why it has a thicker capacity and some higher cut speeds, higher wattage will produce more heat in the power supply, so the fan is needed more often. It is normal for the fan to run more as compared to the 45.
I am also seeing a difference in the voltage settings of around 10v higher from the PM45 to the 45XP to maintain the correct cut heights, I have the XP voltage divider ratio set at 50:1 (factory preset voltage divider)as was my original PM45 The Duramax torch is used with the Powermax45XP. It is designed to handle higher load voltages and the consumable design is quite different as compared to the original torch used with the Powermax45. The XP when at the same physical torch to work distance will show a higher arc voltage reading than the 45 will.
- exapprentice
To Mr Colt
As always regarding Hypertherm products and support, Jim you are a star, couldn't ask for any more than a simple straight forward response
Thanks again for all you do in answering questions and advising not just here but throughout the web
Best Regards to all
Exapprentice
(Pete)
Exapprentice
(Pete)
- SeanP
Was wondering how you were getting on Pete, glad to see you are getting stuck in again.
Funnily enough I just took delivery of the 45XP today, might be a few days before I get to make the switch.
Can I also ask Jim a question which just came to me today while cutting some 2mm on the old 45 using 30a parts, is the old 45 torch with the 30a parts compatible with the 45XP?
I might be tempted to keep that torch for the extra fine/slow speed cuts.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
I believe there is an error in the post for that setting. Two of the values are swapped. At least that is what I ran into.
