my first shares on this site!!
Dooggins1
Post by Dooggins1 »
Here is some of my personal designs i have done for some customers. First file is a sign im currently working on. Second file is a tig rod tube holder i did for myself. I used 1.5" PVC. The last one is a sign i did for a guy to put at the entrance to his property. I would love some feedback!
MOORE.dxf
tig rod holder.dxf
shiloh sign 2.dxf
stdave66
Re: my first shares on this site!!
Post by stdave66 »
Thanks for the share but I am unable to open the files in Corel. Anyone else having trouble with these?
Specialkfab
Post by Specialkfab »
Really good designs. A feedback on the Shiloh sign. I found that when I put letters in a window they are more recognizable by attaching them to either the bottom or top but not both. Just make sure you have enough of the letter attached to be sturdy. Nice job.
DHC2 PlasmaCam 4X4
Pipe Attachment
HyperTherm 45XP
johnp
Post by johnp »
All look good. One little tip I would give is to fillet all of the sharp corners. Experiment with radius of .1 - .25. I find lots of advantages to smoother corners, not the least of which is cleaner cuts. Also not having pointy corners sticking out out on sheet steel is always a good idea.
Cheers,
John P.
Texas Metal Works
My Toys:
otisa2007
Post by otisa2007 »
other than stated above about the sharp corners they looked good thanks for the share keep up the good work
Dooggins1
Post by Dooggins1 »
johnp wrote:All look good. One little tip I would give is to fillet all of the sharp corners. Experiment with radius of .1 - .25. I find lots of advantages to smoother corners, not the least of which is cleaner cuts. Also not having pointy corners sticking out out on sheet steel is always a good idea.
Cheers,
John P.
So like i said I am new to this. What are the advnatages to smoothing out the corners.
Specialkfab
Cheers,
John P.
Its just an appearance thing. I round mine when I can also.
DHC2 PlasmaCam 4X4
Pipe Attachment
HyperTherm 45XP
