Here is some of my personal designs i have done for some customers. First file is a sign im currently working on. Second file is a tig rod tube holder i did for myself. I used 1.5" PVC. The last one is a sign i did for a guy to put at the entrance to his property. I would love some feedback!
my first shares on this site!!
Re: my first shares on this site!!
Thanks for the share but I am unable to open the files in Corel. Anyone else having trouble with these?
- Specialkfab
Really good designs. A feedback on the Shiloh sign. I found that when I put letters in a window they are more recognizable by attaching them to either the bottom or top but not both. Just make sure you have enough of the letter attached to be sturdy. Nice job.
DHC2 PlasmaCam 4X4
Pipe Attachment
HyperTherm 45XP
Pipe Attachment
HyperTherm 45XP
- johnp
All look good. One little tip I would give is to fillet all of the sharp corners. Experiment with radius of .1 - .25. I find lots of advantages to smoother corners, not the least of which is cleaner cuts. Also not having pointy corners sticking out out on sheet steel is always a good idea.
Cheers,
John P.
Cheers,
John P.
- otisa2007
other than stated above about the sharp corners they looked good thanks for the share keep up the good work
johnp wrote:All look good. One little tip I would give is to fillet all of the sharp corners. Experiment with radius of .1 - .25. I find lots of advantages to smoother corners, not the least of which is cleaner cuts. Also not having pointy corners sticking out out on sheet steel is always a good idea.
Cheers,
John P.
So like i said I am new to this. What are the advnatages to smoothing out the corners.
- Specialkfab
Its just an appearance thing. I round mine when I can also.Dooggins1 wrote:johnp wrote:All look good. One little tip I would give is to fillet all of the sharp corners. Experiment with radius of .1 - .25. I find lots of advantages to smoother corners, not the least of which is cleaner cuts. Also not having pointy corners sticking out out on sheet steel is always a good idea.
Cheers,
John P.
DHC2 PlasmaCam 4X4
Pipe Attachment
HyperTherm 45XP
Pipe Attachment
HyperTherm 45XP
