It is currently Mon Oct 15, 2018 7:45 pm
Anyone use a TD Cutmaster 82 for CNC?
Scratch
Postby Scratch » Wed Oct 11, 2017 2:47 pm
I got a good deal on a TD Cutmaster 82 but I'm concerned that I should have got a bigger one. I had a TD 151 and it cut great, but this one stopped cutting after a bit even on some 1/4" steel. I get the duty cycle is lower than my old monster, but is this one too low to keep?
I guess my question is does anyone here cut thick steel like maybe 3/8" on a CNC table with a Cutmaster 82?
Brand X
Re: Anyone use a TD Cutmaster 82 for CNC?
Postby Brand X » Wed Oct 11, 2017 11:23 pm
Duty-cycle is not lower..151 is probably similar at 100% duty-cycle rating.Yes the 151 has more power, but the 82 should cut about the same as a Hypertherm 65 .. I owned all three, and a 42, 52/A-120,101 also.. if it's snapping off on .250, something is really wrong with it .3/8 would still be in the 100% duty-cycle range if using the consumables like 60 amp stuff .70 amp tips work way better then 80 amp on that thickness too,,
Return to “Thermal Dynamics Plasma Cutters”
Users browsing this forum: No registered users and 5 guests
