Probe ignore activated at call for probe error
Can someone help with this? I keep getting this code in the middle of it cutting out stuff. then i cant get it back going in the correct spot so it screws up the whole piece. I just cut something out and worked fine. Did a different piece and started getting this code.
Re: Probe ignore activated at call for probe error
I had this problem a month or so back. Turns out my problem was the probe had dirt in the track and was hanging in the on position. I took it apart and gave it a good cleaning and it worked fine.
Cool Thanks!
i am using plasma cutter with mech3 software
issue that i am facing is probe ignore status
kindly guide me
kindly guide me
