Line Wrapper Upper
lockeyone
Line Wrapper Upper
Post by lockeyone »
I made this file years ago and cut some plexi on my laser last week, just a copy of one that came with some line. Thought someone could use it. I have cut it in wood and plexi but never metal. Probably would be OK in aluminum. The name is just something I thought my Dad would have called it when I was a kid. I keep lots of small line in my camper for rainy weekends for hanging tarps to stay dry. I tend to camp off the beaten path so I just pull out the tarp box and set up if I think its going to rain. Easy to grab each line (different colors) individually as needed. DXF, SVG, PDF in zip file.
line-winder.zip
Epilog Mini 24 60watt, 2013
Re: Line Wrapper Upper
Super cool. Thanks for the share! Your laser does a stellar job, very impressive!
TimP
Post by TimP »
Thank you for the share!
I'm also jealous of your laser.
Tim
david jordan
Post by david jordan »
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Cz_apie
Post by Cz_apie »
thanks,
forever having some pieces of uncoiled rope around, this will fix that for sure
Deon
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
