Design edge not following cutpath
Post your questions or tips on Plasmacam software in this topic.
i_r_machinist
Post by i_r_machinist » Fri Aug 04, 2017 3:16 pm
I have a new trainee and I think he changed a parameter or something because my cutter does not follow the path now.
any ideas?
thanks
i_r_
Gamelord
Re: Design edge not following cutpath
Post by Gamelord » Fri Aug 04, 2017 11:29 pm
Probably added one single dot outside the part and the cutter is going to that dot and then coming back.
see&see
Post by see&see » Sat Aug 05, 2017 10:35 am
Yep, a hard to see almost invisible line remanent with maybe an oversize kerf setting causing the cut path to wander where it thinks it needs to be.
If you want to upload that pcm file myself or someone else here could take a look at it....
PlasmaCam DHC2 4 x 4 & Sampson 510 Hypertherm 85 & 45XP
i_r_machinist
Post by i_r_machinist » Mon Aug 07, 2017 9:19 am
Yup, Kerf settings! All better now.
thanks
i_r_
Return to “Plasmacam Software”
