Hitch covers
stainless_fab
Hitch covers
Post by stainless_fab »
I joined here a long time ago and kinda forgot about this place. I just found it again and am impressed at all the great files here! Here are a couple files that I have made receiver hitch covers with.
BULL RIDER HITCH COVER.dxf
LINEMAN HITCH COVER-1.dxf
Re: Hitch covers
Thanks for sharing.
twobigdawgs
Re: Hitch covers
Post by twobigdawgs »
Thats awesome. I'm always looking for lineman stuff. Thanks. The bull rider is cool too. Thank you for posting! :D
snowman70
Re: Hitch covers
Post by snowman70 »
Did you cut another circle of the same diameter for a backing plate to cover up the 2" square tubing that slides into the receiver hitch? Sorry for the ignorance, I'm brand new at this.
mdwalker
Re: Hitch covers
Post by mdwalker »
snowman70 wrote:Did you cut another circle of the same diameter for a backing plate to cover up the 2" square tubing that slides into the receiver hitch? Sorry for the ignorance, I'm brand new at this.
For hitch covers there is no need to use square tubing. Simply cut a plate that will slide in the receiver tube diagonally and weld your hitch cover to it. I will try to post a pic of what I am talking about later today.
Danny
Danny Walker
Walker Manufacturing
Tishomingo, Oklahoma USA
www.walkermfg.net
dustywill
Re: Hitch covers
Post by dustywill »
Danny
Danny,
Great Idea. I had not thought about that. I a min the process of designing a hitch cover for my students in my manufacturing class to make and sell. Would you mind posting a dxf (I know it is simple) of the shaft you use? I know it should be some sort of ellipse if the pin fits it well.
Also, what do you get for hitch covers like the lineman one?
Precision Plasma 4x8 v-rail
C&CNC dragon cut 620
Hypertherm Powermax 45
Auburn, AL
www.facebook.com/decorativemetalworks
mdwalker
Re: Hitch covers
Post by mdwalker »
Finally remembered to take a picture of the hitch cover. On future ones I will cut several holes for the hitch pin spaced approximately 1" apart so the cover can be adjusted in or out to fit each vehicle.
Danny Walker
www.walkermfg.net
motoguy
Re: Hitch covers
Post by motoguy »
I love the diagonal plate idea, vs cutting square tubing. Also love the adjustable hole idea. I know it's old, but thanks!
4dycefabrication
Re: Hitch covers
Post by 4dycefabrication »
that is a great idea vs, tubing!!!
Wraazer
Re: Hitch covers
Post by Wraazer »
Funbum
Re: Hitch covers
Post by Funbum »
Really neat!! Thank you!!
bigworm36
Re: Hitch covers
Post by bigworm36 »
Question on the diagonal plate. Does the plate slide back and forth horizontal in the receiver since it is not a tube. Seems like there would be a lot of slop. Or maybe I do not under stand the plate fully how it slides in.
Arclight 5x5 table
Delta 3 CandCNC controller
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
motoguy
Re: Hitch covers
Post by motoguy »
bigworm36 wrote:Question on the diagonal plate. Does the plate slide back and forth horizontal in the receiver since it is not a tube. Seems like there would be a lot of slop. Or maybe I do not under stand the plate fully how it slides in.
If it's at a 45 angle, it would be wedged against the inside corners of the receiver tube. Maybe a bit ratty, but shouldn't move much.
bigworm36
Re: Hitch covers
Post by bigworm36 »
I'm looking at the picture above I still don't see a diagonal in the peice. Is there a picture showing the concept better. Sorry I can be a little slow at times !
Arclight 5x5 table
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Gamelord
4.5 Star Member
4.5 Star Member
Re: Hitch covers
Post by Gamelord »
When you insert the piece into the hitch receiver, the part that goes into the receiver is welded on a diagonal instead of being horizontal or vertical. That is the reason for the slot in the end instead of a single hole. That way it doesn't flop around. By putting it on a diagonal, you only need one piece of steel to hold it into place instead of a square tube.
james.davis
Re: Hitch covers
Post by james.davis »
What a great idea. Some smart people on Plasmaspider ;)
Jim
bigworm36
Re: Hitch covers
Post by bigworm36 »
Gamelord wrote:When you insert the piece into the hitch receiver, the part that goes into the receiver is welded on a diagonal instead of being horizontal or vertical. That is the reason for the slot in the end instead of a single hole. That way it doesn't flop around. By putting it on a diagonal, you only need one piece of steel to hold it into place instead of a square tube.
Got it ! Thank you. For some reason I was thinking of something a little different but this is a great idea no that I under stand it!
Arclight 5x5 table
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
hemichargersrt8
Re: Hitch covers
Post by hemichargersrt8 »
Here is the diagonal plate for 10 ga steel, a 6 inch circle template that can be used to locate the diagonal mounting holes on your artwork and modified bull rider file as posted by the original poster.
bull rider hitch cover modified.DXF
trailer hitch art template- 10 ga ms.DXF
trailer hitch tab- 10 ga ms.DXF
Gamelord
4.5 Star Member
4.5 Star Member
Re: Hitch covers
Post by Gamelord »
Your 3D skills are envious. :) Thanks for the awesome visual...and the files.
steel 35
Re: Hitch covers
Post by steel 35 »
Yes they are & Thanks for sharing.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
bigworm36
Re: Hitch covers
Post by bigworm36 »
So awesome thank you for sharing ! What 3D CAD software do you use and how do you like it?
Arclight 5x5 table
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
hemichargersrt8
Re: Hitch covers
I use Solidworks
bigworm36
Re: Hitch covers
Post by bigworm36 »
I like solid works I use CREO at work and solid edge at home, I got a free year subscription so trying it out. I may look at solid works after it is expired.
Arclight 5x5 table
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Redneck
Re: Hitch covers
Post by Redneck »
Thank you for the files.
2015cmax
Re: Hitch covers
Post by 2015cmax »
I used a telescoping tube like the tubing used for road sign post for the few hitch covers I have done. (See attacked picture).
While learning how to use my plasma table I modified a design I saw here to create a cover for my neighbor who is a fire fighter. (sorry I don't remember who to thank). I did not like how the first one came out so I tried getting into more detail with the CAD program and came up with one custom to his department. It was a one of piece, and since I was just starting out I did not save the file.
The tubing is nearly a perfect fit into the receiver, little to no rattle, hole are already centered and I just drilled them out to the diameter of the hitch pin. The design could still use improvements and refining, but he like it.
