What is the name of this part?
- GoingCustom
Anyone happen to know what this part is called and/or where I can order one? It attaches to the shaft of the z-axis servo. Thank you
- GoingCustom
Re: What is the name of this part?
flexible coupling
You will need to know both in and out shaft sizes. They may or may not be the same.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Miller 350P
- tnbndr
I would contact Dan he should know
Consider replacing it with an Oldham style coupling to avoid future breakages from wind up
4x4 DIY Plasma Table
Hypertherm PM45
Purelogic THC
Mach3
Inkscape
Hypertherm PM45
Purelogic THC
Mach3
Inkscape
there are tons of them on eBay but from china many weeks for shipping
http://www.ebay.com/itm/Brand-New-CNC-8 ... SwjDZYmq58
local supplier for similar to above would be WWW Graingers (love joy coupling) but I don't think they are metric.
- GoingCustom
Thank you. Realized that once I figured out what it was.sphurley wrote:You will need to know both in and out shaft sizes. They may or may not be the same.
Sent him an email, but haven't heard back yet. Just need to get back up and running ASAP.tnbndr wrote:I would contact Dan he should know
I hadn't seen that before! Thank you for the suggestion, I'll look into it!AndrewMawson wrote:Consider replacing it with an Oldham style coupling to avoid future breakages from wind up
Miller 350P
Miller 350P
For future reference, remember to measure the height of your old coupling before you buy a new one. The Lovejoy ones (L050) are alot taller, but I was able to make it work despite. May not be as easy to accommodate on another table.
