Pcam Ohmic sensor wire
barefoot3zk5
Post by barefoot3zk5 »
over the weekend .. I had the misfortune of breaking the component in the wire that connects to the Ohmic sensor .. what xactly is it ??? (resistor) im guessin ??? I'm sure it should be available locally and jus soldered back in line .. currently running DHC II with DHC Designedge .. thanx
Re: Pcam Ohmic sensor wire
Best bet is to go to the Plasmacam owners community on their website. I'm sure one of the thousands of owners that share info on that site will help you out in a few minutes. You do have to join to post on that site....you will need your machine serial number to do so. Jim Colt Hypertherm
It is a resistor, but since I have never broken mine....I'm not sure of the resistance. I'm thinking it was 470 ohms...
barefoot3zk5
as always .. Thanx U Jim C .. took old broke down to electronics store and decoded the colored bands and back up and going again .. wish I could get some curly q wire to replace that lil piuece .. lol
Bobcat320
Post by Bobcat320 »
Hey Barefoot,
Do you mind sharing which resistor you came up with... Just in case at some point I should have an issue with mine!
Carl
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Francisco
Post by Francisco »
47 kOhm
Bobcat320
Post by Bobcat320 »
Thank you!
PlasmaCam DHC2
Hyperthem PM65
Joe Jones
Post by Joe Jones »
jimcolt wrote:Best bet is to go to the Plasmacam owners community on their website. I'm sure one of the thousands of owners that share info on that site will help you out in a few minutes.
Yep. Last time I counted, there were THOUSANDS of contributors on the Owners Community. :lol: :lol: :lol: :lol:
PlasmaMac
Post by PlasmaMac »
Something like is can be repaired with a few items from the hardware store typically. Its pretty much consists of a wire connected to a diode, protected by some electrical shrink tube and a spade connector on the end. Best bet is to either call plasmacams tech line for any specifics. As mentioned previously, plasmacam's owners community could also be helpful.
