I have run into a problem a few times with dxf not working. I use qcad, occasionally I find a file that will not open there. I have used some of the files from the forum and they open, others do not. Any thoughts?
david
dxf compatibility
dxf compatibility
home built 4x4 watertable. Qcad, SheetCam and Linuxcnc
Miller 375 Cutmate
Lincoln buzz box and a Miller Mig
KNK MAXX vinyl cutter
The adventure started with a Cricut cutter that I hacked.
Miller 375 Cutmate
Re: dxf compatibility
Some software just don't play nice with other software, nothing you can do about it.
Even though it is in a format (DXF) does not mean you can read it.
Interesting thing is Sheetcam can read it just fine. I had not tried that before, I got hung up thinking I had to preview it in qcad.
david
david
Miller 375 Cutmate
Miller 375 Cutmate
you can download a program called Irfan view and then get the DXF plug in you can display DXF files very easy like displaying jpeg or bmap images.
free too.
free too.
Thanks for that!acourtjester wrote:you can download a program called Irfan view and then get the DXF plug in you can display DXF files very easy like displaying jpeg or bmap images.
free too.
