So I came up with the attached, it's a conductive plate that surrounds the torch tip, mounted to the torch holder separated by nylon spacers. An electrical wire comes from the conductive plate and one comes from the slats of the table, these two wires goes to the B.O.B as an E-STOP input, therefore as a tip-up makes contact with the conductive plate it closes the circuit an triggers the E-stop.
Will this work? or will I fry my Break-out Board because of the ground of the plasma cutter which is also connected to the slats?
Thanks in advance and apologies if this is a stupid idea
![Shocked :shock:](./images/smilies/icon_eek.gif)
