Fan Clutch Spanners
Fan Clutch Spanners
Metric and Standard. Need to adjust your kerf offset accordingly.
Andrew Spurr Owner of SS LLC Est. 2011
Miller Millermatic 252, Miller Millermatic 212 Autoset, Miller Bobcat 225, Miller Syncrowave 210
Lincoln LN25
JD2 Programmable Bender
Thermodynamics 42
Hypertherm 45, 65 with machine torch
Trucut Series One 4x8
Lincoln LN25
Thermodynamics 42
- Zippo
Re: Fan Clutch Spanners
Thanks for posting.
- someguy
Very handy, thanks for the post.
- little blue choo
OK, I own a auto repair shop and have been a ASE certified Master Tech for over 40 years. I own and use fan clutch wrenches on a regular basis but don't under stand the hook on the end. Can someone help me here? I know I must be missing something. Not blond but I am getting old. LOL
Rick
Arclight 9600 4x8 table
It's for using an air hammer to break the fan nut loose and tighten it without having to hold the fan clutch from rotating. Just put the wrench on in the right orientation and put your air hammer in the hook, hit it with a couple of quick bursts from the air hammer and the fan will come loose. Great tools. Built one for a buddy of mine that works for GM and he loves it. You can also add in your initials when cutting just to guarantee it doesn't find a new home!
- little blue choo
Why did I not know that. I saw this system in one of our trade mag's a year or so ago. Like I said, I'm getting OLD! LOL
Rick
I just changed the water pump on my 7.3l Ford and had to borrow one from a student. Reverse engineering his was on my list to do but now I will not have to. Thank you very much. I also like the air hammer hook. His did not have that. These things are a life saver.
Thank you
Great file!! Thanks
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
I just cut and used these! AMAZING! Thank you so much!
What thickness of metal do you use? I was thinking of 10 ga. Thank you
I would go with 1/4" or 3/16" at the very least. I'd be afraid 10 ga might spread apart. Some of those fan clutches can be pretty tight!teachag wrote:What thickness of metal do you use? I was thinking of 10 ga. Thank you
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Duramax mini torch with Snap n Cut
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
- little blue choo
Teachag, I would use tool steel if possible. I cut one out of 1/4 and it spread the first time I used it. Like MetalTorcher said they can be pretty tight. Mine was on a diesel. It worked but I had to use my MAC TOOL one to put it back. Thank goodness I just cut one to try.
Rick
Rick
Rick
Saved and cut just the 2" one. Added a handle to it and it worked like a charm.
Many thanks!!!
Many thanks!!!
rockstar metalworks wrote:It's for using an air hammer to break the fan nut loose and tighten it without having to hold the fan clutch from rotating. Just put the wrench on in the right orientation and put your air hammer in the hook, hit it with a couple of quick bursts from the air hammer and the fan will come loose. Great tools. Built one for a buddy of mine that works for GM and he loves it. You can also add in your initials when cutting just to guarantee it doesn't find a new home!
Can you post a picture of the air hammer being used with the wrench. I know you explained it above but I just cant picture it. Some times I need to see it being used to understand it.
Thanks Gary
The dxf. file is not downloading onto my computer. How do I download?
thanks!
thanks!
- Scratch
You'll have to use the correct chisel tip but here's how you would use it:ggeh wrote:rockstar metalworks wrote:It's for using an air hammer to break the fan nut loose and tighten it without having to hold the fan clutch from rotating. Just put the wrench on in the right orientation and put your air hammer in the hook, hit it with a couple of quick bursts from the air hammer and the fan will come loose. Great tools. Built one for a buddy of mine that works for GM and he loves it. You can also add in your initials when cutting just to guarantee it doesn't find a new home!
Thanks Gary
A pictures worth a thousand words. Thanks for taking the time, very helpful I get it now.
Thanks, Gary
Thanks, Gary
thanks
simply wonderful!
