home built z's postem up if any
HammerDownJustin
Post by HammerDownJustin »
Just curious how many people built there own z axis? I'm thinking about building one for the cnc router table Im fixing to do. Mine on my homebuilt table was a kit from droid cnc or whatever his name was out of Oklahoma years ago.. Thank you just wanting some fresh ideas.
Miller 251 Mig
HammerDownJustin
Re: home built z's postem up if any
Pretty nice
Miller 251 Mig
Here is mine
HammerDownJustin
Are the screw drives very hard to figure out the steps when setting motors up? Fixing to start a wood router table next for the wood shop. My current z on my plasma table is rack and pinon.
Miller 251 Mig
Simko
Post by Simko »
HammerDownJustin wrote:Are the screw drives very hard to figure out the steps when setting motors up? Fixing to start a wood router table next for the wood shop. My current z on my plasma table is rack and pinon.
I just set mine up on Sunday. My z is direct coupled (no belt reduction) If you know the screw pitch, it's pretty easy. 0.200" pitch is 5 turns per inch, 0.100" pitch is 10 turns per inch. Some screws are rated in threads per inch and number of starts. A 10 thread per inch, 2-start screw is the same as a 5 turn per inch screw. A 10 thread per inch, 1-start screw is the same as a 10 turn per inch screw.
Number of threads per inch divided but the number of starts = number of turns per inch.
Pitch = 1" / number of turns per inch.
Number of steps for one rev of stepper - 200
10x micro stepping = 200 revs X 10 =2000 steps per rev
0.200" pitch screw is 5 turns per inch X 2000 steps per rev (turn) = 10,000 steps per inch
I used exactly 10,000 steps when I set mine up and I was within 0.0005" (yes,a half thousandth)
I would say they are easier to set up than rack and pinion.
Homebrewed plasma table in the works, NSK linear rails, 3.2:1 belt reduction, CandCNC Plazpak 1A with DTHCIV Ethercut, Hypertherm 85, CommandCNC and SheetCAM
Click here for build post
HammerDownJustin
Thank you and yep when i set my rack and pinon up it was easy because there was a company that used to have a online calculator that gave you the number,,
Miller 251 Mig
Setting up the Z for a lead screw is easy just use Mach's "Steps per" cal under settings page. quick and easy no math involved.
I used rack Z on my first table but changes as the torch would drop when power was removed.
exapprentice
Post by exapprentice »
Somewhere in one of CandCNC manuals you can find the equation for calculating how to change the number of steps based over a distance to fine tune your table ;)
Best Regards to all
Exapprentice :D
(Pete)
leggman
Post by leggman »
My first build. works great
Mckenny87sj
Post by Mckenny87sj »
Holyshit leggman that was the best i have ever seen
