Moto Skeleton
JoeyD
Moto Skeleton
Post by JoeyD »
Hey everybody. Here is a DXF file that I cut out for a customer's motorcycle shop. Bryant Henry converted this file for me and did an AWESOME job. Here is his email if you are interested in his work. idahobry at yahoo.com
Motoskull.dxf
Re: Moto Skeleton
nice file Thanks for sharing.
raven_storm_69
Re: Moto Skeleton
Post by raven_storm_69 »
Nice work Joey.
Russ K
Re: Moto Skeleton
Post by Russ K »
JoeyD, I would like to personally thank you for sharing your Moto Skeleton file. I have cut several of these out, with modifications, for the motorcycle fraternity in the Seattle/Tacoma area. Something about it clicks with those crazy two wheelers! Thanks again and tell your Designer that he does great work.............Russ K.
JoeyD
Re: Moto Skeleton
Post by JoeyD »
You're very welcome, Russ! Bryant Henry did the conversion for me and I think it turned out great!
mattinspokane
Re: Moto Skeleton
Post by mattinspokane »
nice work!! this will look good hanging in my shop.
Metal Man
Re: Moto Skeleton
Post by Metal Man »
has this file been cut if so was the file cut as posted :?:
JoeyD
Re: Moto Skeleton
Post by JoeyD »
Yes, this file was cut. I only posted the drawing not the cut paths. I use a Plasmacam and it turns out great!
Metal Man
Re: Moto Skeleton
Post by Metal Man »
I understand .great file thanks abunch :D
p m metals
Re: Moto Skeleton
Post by p m metals »
nodes need connected on file
ColoradoWayne
Re: Moto Skeleton
Post by ColoradoWayne »
I think there is a significant difference between what Plasmacam uses and what Sheetcam and Autocad can use. Lots of problems with the file for me, open nodes where the lead ins were and corners that crossed themselves. But it is a really cool design so I played with it for a while. Not sure I caught everything, but for those of you not using plasmacam take a look at this file, it may work a little better for you? I never was able to connect the lines, not sure what that is about.
JoeyD, thanks for the file - it is a very cool design. I will use it, for sure! Keep up the good work. :D
Tribal bike skeleton.dxf
Wayne
LDR Motion Systems 4 x 4 water table
Hypertherm Powermax 65
steel 35
Re: Moto Skeleton
Post by steel 35 »
ColoradoWayne wrote:I think there is a significant difference between what Plasmacam uses and what Sheetcam and Autocad can use. Lots of problems with the file for me, open nodes where the lead ins were and corners that crossed themselves. But it is a really cool design so I played with it for a while. Not sure I caught everything, but for those of you not using plasmacam take a look at this file, it may work a little better for you? I never was able to connect the lines, not sure what that is about.
I connected a few extra starts and joined your layers, Sheetcam likes this one a little better thanks for the great start.
Tribal bike skeleton2.dxf
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
ColoradoWayne
Re: Moto Skeleton
Joined layers - that is probably why I could not join the lines. How do you join layers?
Wayne
steel 35
Re: Moto Skeleton
Post by steel 35 »
I opened your file after playing with the first one and you made it way past me on rounding the edges! When opened in sheetcam there were 4 layers, I cheated and opened it in a Vcarve / Corel style program, selected all and clicked Join, there are almost 1000. Another trick I learned on this fabulous site.
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
ColoradoWayne
Re: Moto Skeleton
I think we are all always looking for little tricks to improve the process or the work. Thanks for sharing.
Wayne
p m metals
Re: Moto Skeleton
when I open this file all the nodes are not connected can anyone help with this I'm using corel draw thanks so much
Cz_apie
Re: Moto Skeleton
Post by Cz_apie »
p m metals wrote:when I open this file all the nodes are not connected can anyone help with this I'm using corel draw thanks so much
p m metals
Try this one, all connected in plasmacam and exported as DXF
skeleton rider 3 no intersections.dxf
Deon
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
