Hi all, yet another file that is not mine.. It is different from the other Christmas tree posted.. For the life of me, I cant figure out what the little things at the top of the file are for
April
Another christmas 3d christmas tree
- parrotlady
- Weldtutor
Re: Another christmas 3d christmas tree
The circular items at the top of the drawing could be used for decorations.
Note the 10 stars, with 6 points, have a joined point that will let them be bent out of the flat tree surface.
The 10 circles each have 3 tabs, & are a size that could be inserted into the star openings as decorative ornaments, secured by bending the tabs.
See picture attached.
- parrotlady
ohhhhh that makes sense! Thanks!
just to complicat things. if you made this out of thick enough stock. once you bent the stars at 90 degrees from tree. you could wel the round things to the bent star. up turn the tabe and you would have a tea light or candle holder.
