Swirl Ring
seajinx
Swirl Ring
Post by seajinx »
When going with a 45 Amp fine cut tip on my table, is it necessary to change out the swirl ring and electrode to a 45 Amp ring? Trying to build knowledge as I go along.
ArcLight 1200
HP 85
Miller Syncrowave 200 W/Water Cooler
Lincoln 225 Mig
Re: Swirl Ring
Here are the recommended consumables copied from the Powermax85 operators manual for FineCut consumables, machine cutting:
all finecut cons.jpg (25.59 KiB) Viewed 952 times
As you can see, the 220857 swirl ring is recommended....this is the same swirl ring used with the 45, 65, and 85 amp consumables. There is a different part number for the swirl ring if you are hand held cutting and have issues with the plasma arc transferring to the material when edge starting. This hand cutting swirl ring is not recommended for machine cutting, and not needed in 99% of the hand cutting applications.
Jim Colt Hypertherm
michmetalman
Re: Swirl Ring
Post by michmetalman »
How long does a swirl ring generally last?
agteacher
Re: Swirl Ring
Post by agteacher »
michmetalman wrote:How long does a swirl ring generally last?
This is my question also, or how do you know it is time to change it?
Randy Dobbins
Welding Teacher Humble ISD
Re: Swirl Ring
We sell about 50 nozzles for every swirl ring. If the swirl ring has no damage, has no burn marks and your torch does not misfire.....then it is probably good. The swirl ring is an insulator (between the positive nozzle and the negative electrode), it is a bearing that allows the blowback electrode to slide freely, it controls the air flow and swirl rate....and it aligns the nozzle and electrode for good cut concentricity.
Jim Colt Hypertherm
seajinx
Re: Swirl Ring
Post by seajinx »
jimcolt wrote:Here are the recommended consumables copied from the Powermax85 operators manual for FineCut consumables, machine cutting:
Jim Colt Hypertherm
Thanks Jim.
agteacher
Re: Swirl Ring
Post by agteacher »
jimcolt wrote:We sell about 50 nozzles for every swirl ring. If the swirl ring has no damage, has no burn marks and your torch does not misfire.....then it is probably good. The swirl ring is an insulator (between the positive nozzle and the negative electrode), it is a bearing that allows the blowback electrode to slide freely, it controls the air flow and swirl rate....and it aligns the nozzle and electrode for good cut concentricity.
Jim Colt Hypertherm
Thank you!
Randy Dobbins
gblaylo
Re: Swirl Ring
Post by gblaylo »
Jim Colt Hypertherm
Hi Jim
On a cnc machine with a machine torch (Hyperthem 65) and fine cut consumables, Candcnc electronics, should I be using the 220948 shield or the 220955 deflector. Currently I use the shield.
Gary
Re: Swirl Ring
If you are using CandCNC's feather touch you will need to use the Shield (220948 plus 220953 retaining cap) as it makes contact with the metal before the tip of the fine cut.
Re: Swirl Ring
The shield is always the best choice.
