Grease Fittings
SlackerMan9
Grease Fittings
Post by SlackerMan9 »
Hey Dynatorch Owners - what kind of grease gun do you use to grease the linear slides. I have a new table and my standard grease gun fitting is too fat/big to fit onto the zerk. Is there a micro gun or something?
bjinxed16
Re: Grease Fittings
Post by bjinxed16 »
Contact Dynatorch. They can give you the size and they even have the grease gun adaptor that they sell.
War Hammer
Re: Grease Fittings
Post by War Hammer »
When you do get the gun set up make sure you run Mystik JT-6
We used to just run a generic grease on the table. With a recommendation from Dynatorch we switched to the JT-6. the table glides much smoother. we won't go back.
Jearnest13
Re: Grease Fittings
Post by Jearnest13 »
Did you ever find out the answer to this? I'm having the exact same problem.
cstroke
Re: Grease Fittings
Post by cstroke »
SUBSCRIBING...
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
