Hey Dynatorch Owners - what kind of grease gun do you use to grease the linear slides. I have a new table and my standard grease gun fitting is too fat/big to fit onto the zerk. Is there a micro gun or something?
Grease Fittings
Re: Grease Fittings
Contact Dynatorch. They can give you the size and they even have the grease gun adaptor that they sell.
Re: Grease Fittings
When you do get the gun set up make sure you run Mystik JT-6
We used to just run a generic grease on the table. With a recommendation from Dynatorch we switched to the JT-6. the table glides much smoother. we won't go back.
Re: Grease Fittings
Did you ever find out the answer to this? I'm having the exact same problem.
- cstroke
Re: Grease Fittings
SUBSCRIBING...
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
